gauges problem
Discussion in 'The Garage' started by chris12, Sep 30, 2006.
  1. chris12
    chris12 1/2 ton status
    Apr 23, 2006
    267
    Forest Ontario, 1/4 hr from Port Huron Michigan
    What will cause my gas gauge to read full and a half. It never moves. Also all the other gauges in my 88 K-5. But my speedo does work but its not accurate. Can anybody help me out.
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    If by "full an a half" you mean the needle is at 3 o'clock, than you've lost your ground somewhere between the gauge and the ground at the fuel tank sending unit. I've got a troubleshooting guide and a generic wiring diagram I can email you if you want. PM me, as I don't keep up on reading the forums very well, if you want them.
  3. chris12
    Apr 23, 2006
    267
    I will try tracing the ground.Thanks
  4. chris12
    Apr 23, 2006
    267
  5. alec78
    Aug 5, 2002
    358
    Washington
    Sorry, I forgot about that... Emailed it to you...
  6. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    If you left click on the name a window opens, next left click on Email:
    Send a message via email to alec78 however the user has selected to NOT receive emails!!! :(
    Some one had this problem a little while ago and here was the reply to it.
    There is a company that deals with this also http://www.fix-a-gauge.com/faq.php
    Q.: How Does a Gauge Work Or What's Wrong With My Gauge Anyway!!??
    Ans: All gauge systems consist of two major parts.
    The sending unit does just that, it sends the pressure, temperature, voltage, amperage and levels to a remote indicator (gauge). The gauge has to be calibrated to the sending unit. This calibration is accomplished via a shunt, located on the back of the gauge.
    The shunt provided by the OEM is mounted on a ceramic substrate or base. The ceramic is sensitive to temperature changes, i.e: expands when hot, retracts when cold. The ceramic substrate expands and retracts, BUT the shunt does not expand or retract. This movement causes the shunt to fail (open circuit), making the gauge useless.
    Vehicles have extreme temperature changes daily. Imagine a car sitting in the sun in August. The temperature inside the car can rise to near 180 degrees. You get inside turn on the AC and within 30 minutes you have the temp below 70.... The reverse in the winter....​
    Q.: Will Fix - A - Gauge fix my vehicle's gauges?
    Ans.: If your gauge has a white ceramic plate across two terminals on the back, FIX-A-GAUGE will work.
    Q.: What models years does Fix - A - Gauge fix?
    Ans.: Fix-A-Gauge works on model years 1969-1993 of General Motors vehicles, International trucks and busses, John Deere and Case tractors.
    Q.: How do I know my fuel gauge is broken?
    Ans.: Fuel will indicate 1/4 of a tank when full. The needle will not move until tank is under 1/4 of a tank.
    Q.: How do I know when my temperature gauge is broken?
    Ans.: The temperature gauge will show hot all the time.
    Q.: How do I know when my oil gauge is broken?
    Ans.: The oil gauge will show low oil pressure all the time.
