Gauges
Discussion in 'The Garage' started by NoReGrEtS, Feb 20, 2006.
  1. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    I was lookin to get new gauges what size fits some what in the stock gauge cluster?
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    This article has quite a bit of detail (and photos):
    http://www.73-87.com/7387garage/interior/gauges_recessed.htm
    He also has another article there dealing with the easier method, which is surface-mounting the gauges.
    You can buy complete bezels in various finishes with various gauge sets already surface mounted from places like Covan's Classics (places like Summit are resellers). This ready-made solution is bound to be much easier and faster, but also more expensive, so it all depends on the thickness of your wallet.
    If you want to change everything out in a single afternoon and have extra cash to burn, the ready-to-go panel would be sorely tempting.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    i just went to car-part.com and got a factory replacement... with factory tach.... for $25 to my door... :wink1:
  4. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    I think the biggest gauge headache for most older 4x4 owners (or should I say owners of older 4x4s) is a mechanical speedometer. With tire size and axle ratio changes, the calibration can get off true in a hurry. Replacing a mech speedo with an aftermarket, easily recalibrated, electronic speedo has a lot of advantages, if you intend your often-modified 4x4 to spend much time on the street.
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    automatic owners can buy the gears for the speedo that fix that..
    however my speedo is wrong and I got a manual trans...so I know what you mean..
    I wouldnt mind putting a electronic self one in... what kinds are reasonable that may look factory?
    I just use my ipaq as a speedometer right now.... (gps)
  6. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    If you're bored and have gauges laying around can do this.
    Had more time than cash, But looks good and yes speedo is fubar.
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    hey CB77GMC - what are those gauges out of? did they just click into the stock cluster and just need a few different wires?
    I want to do the tach, fuel gauge but they are so $$$$$$$$$$$$4
  8. NoReGrEtS
    Nov 7, 2005
    848
    Thanks that is what I was looking for
    The covan classic's are nice Im thinking of get one of there setups
    I have a sm465 can I change it to an electrical speedo?
  9. NoReGrEtS
    Nov 7, 2005
    848
  10. CB77GMC
    May 6, 2005
    771
    Heath Springs, SC
    2" sunpro gauges mech, Oil, Temp, Amp, Volts all had to be wired. Can be picked up at most auto stores about $20.
    I cut the stock cluster out little tricky "used mini grinder" and some wiring for lights.
    Project took about 2 days. Main PITA was gauge placement took look right with stock holes. Like I said more time than money.
    But hind sight. If I had used sunpro electric gauges could have taped in to all right at gauges.
