Gave the crewcab a tune up and now won't start??? *Update*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5DRAGER, Jan 20, 2004.
  1. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Gave the crewcab a tune up and now won\'t start??? *Update*
    Well I give up for the night. Gave the crew cab a tune up and now it won't start. /forums/images/graemlins/angryfire.gif Here's what I changed: new cap and rotor, new MSD coil, new MSD super conductor wires, NGK spark plugs, and new O2 sensor. And now it will turn over but will not fire. Its getting gas.. believe me I know. So I think some where its not getting spark or at least not enough spark. I tried putting the old coil back in, in case the new one was bad but that didn't help. Looking for any suggestions here so I can get it running and go get the new exhaust put on. I have also looked for anything that may have come unplugged. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Re: Gave the crewcab a tune up and now won\'t start???
    Could have got the wires crossed.. I have done that more times then I care to remember.. /forums/images/graemlins/thumb.gif
  3. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Had the same problem last time I tuned up my 84 K5. I forgot the little 2 (or 3...can't remember off hand) wire connector that plugs into the rear driver side of the cap. Did you double check that? After I found that, and beat my head against the steering wheel numerous time, I cranked right up and ran like a champ. Hope that helps!
    Kris
  4. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Triple check all connections.
    Make sure you got a good 12V at the distributor.
    Pull a plug wire and check for spark.
    These are the first things I check. If still no spark, check the ignition module thingy. After that it depends on what you got, You said O2 sensor so I assume its got a brain and a bunch of sensors, good luck.
  5. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Both plugs are plugged into the cap. I don't know maybe I'm one off on the cap? Sorry guys forgot to mention that its a 88 old body style. Thanks
  6. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Do you have spark at the wires????? If not check for the little ground strap inside the cap from the side of the coil to the center of the connector on the cap. I've forgot that before and it would'nt fire at all, just turns over.
    Bill
  7. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Mine is a tbi with the external coil. I painted the brackets that hold it to the engine and thought it might need a good ground and took it back off and scaped the paint away where it makes contact with the coil and engine. Still didn't help. I took a plug out and turned it over and did have spark , it looked a little weak to me but it was hard to tell. Anyone else?
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Wires are crossed like Dan said. I've done that too many times, too. /forums/images/graemlins/blush.gif /forums/images/graemlins/thinking.gif
  9. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Ditto!
    Bill
  10. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    If its a small block the corrct order is 18436572. I have seen lots that you put wires on and then it wont start, becuase #1 is in the wrong spot, Meaning some jack a$$ pulled the distrubtor and put it back in in the wrong spot and # 1 isnt where its supposed to be. I would pull #1 plug and the cap and bump the motor till air puffs from th eplug hole and see where the rotor is pointing.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's not a small block, its a 454, but the firing order is still 18436572.
    Brent, you sure you pushed the rotor down all the way? That new style distributor has a silly push on rotor instead of a normal screw on one. A few weeks ago I tuned one up and hadn't pushed the rotor down all the way, it was like 60* out of time and wouldn't start so I had to pull the cap back off and find it. Yeah, stupid, but it just needed a little nudge and the truck started right up.
  12. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    I'll check the cap and rotor and the placement of the wires on the cap tonight. Thanks all I'll let ya know what I find. /forums/images/graemlins/thumb.gif
  13. dyeager535
    26,982
    191
    If you play around with other GM products like I do, (Oldsmobile) make sure you remembered the correct distributor rotation direction for a Chev motor when you did the plug wires. BTDT. /forums/images/graemlins/smile.gif
  14. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Sounds to me like it could be two problems. If your getting spark, and fuel, but the motor still wont start, then you have either put the wires on the cap in the wrong order, or have the distributor in wrong. Obviously, if the motor is getting gas and you said you saw spark too, its gotts be something in the timing. Take the dist. cap off, and make sure that the rotor is pointing between the 1st and 3rd cylinders. Also, check to be sure that when the rotor is pointing between the 1st and 3rd cylinders, the number 1 cylinder is on the compression stroke. An easy way to do this is to pull the number one plug, put your thumb over the hole, and bump the engine untill you feel air comming out. Once you get that right, put the cap back on, connect the wires (trace all of them to make sure they go from the correct cylinder to the correct pin on the distributor cap), starting from the number one wire working clockwise to number 8. Then your motor should fire right up. Its been a while since ive messed with timing, so if I have messed up on anything, somebody please correct me. Hope this helps. Let us know what happens.
    -Harrison
  15. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Here's a quick update. I did have the wires on the cap wrong. But that didn't help any. And as far as I know I'm now not getting any spark to the cap. I pulled the coil wire off the cap and laid it next to the terminal and had the wife crank it over and nothing. At this point I have froze my butt off for the last 3 night and am going crazy. Called the cuz up and he's taking it out to the heated shop to diagnose the problem.
  16. 87BrnRsd
    Apr 21, 2003
    2,457
    I know how it is out in the cold. Let us know what it was when you get it fixed.
    -Harrison
  17. thatK30guy
    Jan 12, 2001
    32,076
    55
    Could the timing be off 180 degrees? /forums/images/graemlins/thinking.gif
  18. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    I don't think so, I never had the distributor out, just put on a new cap and rotor? And yeah, I'll post a update when we find out.
  19. Grim-Reaper
    7,385
    Atlanta
    This the one for sale? ......Must be a bad motor. I'll come get it off your hands and save the rebuild costs. How's $500 sound? /forums/images/graemlins/rotfl.gif
    Go back and retrace what you did. Trun the motor to TDC and set up the firing order from there.
    I'm telling you its going to be something dumb like a loose plug to the cap, Module or one spot off on the firing order.
    Hay did your cap have a ground wire for the coil or was it the little metal strap that everybody forgets?
  20. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    This is a TBI motor that has an external coil. And as far as I know its grounded through the brackets to the manifold. I didn't see any ground wire attached to it?
