GD snap rings! aaaarrrrhhhggggg
Discussion in 'The Garage' started by jekbrown, Aug 13, 2002.
  1. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    i just spent over an hour trying to get a f'in snap ring back on. Its a big sucker, about 1.5" across... goes on the tcase's front output shaft.. its the type that is just "C" shaped... it doesnt have the lil loops for the snap ring pliers. At any rate, does anyone have a trick for snap rings? I have snap ring pliers, but they arent big enough... dont open wide enough.. its really close... just doesnt quuuuite make it. any tips/tricks/advice would be greatly appreciated, thanks!
    J
  2. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    I feel your pain. Try to set one end almost on the take a screwdriver (flat head) to pry the other side on. MAKE SURE YOU KEEP YOUR HAND ON TOP SOMETIMES IT LIKES TO FLY OFF!!!!!!!!!!!!!!!!!!! Then just try again. /forums/images/icons/grin.gif
  3. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    yeppers, thats the problem with being to cute with a screwdriver. bad times. a BIG pair of snap ring pliers would prolly do it. Gawd damn it, I *hate* working on trucks when you dont have the RIGHT tools!!!!!! aaaaaaarrrrrrrhhhhhhgggggggg /forums/images/icons/frown.gif /forums/images/icons/crazy.gif /forums/images/icons/confused.gif
    J
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Are you saying that you'd be able to use the pliers if they opened wider... If so try adding some material to the pliers, a rough example would be to tape some metal on them ....Know what I mean.... /forums/images/icons/wink.gif
  5. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    Good idea. /forums/images/icons/grin.gif
  6. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    hmmmmm...
    <heads back out to the garage...>
    J
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    Thank you thank you, it comes from years of not having the right tool, it's called turning sh!t into icecream....LOL /forums/images/icons/laugh.gif
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'v done sh!t like use a big socket and a hammer to force them on. Also a pipe wrench. Just big enough to fit over whatever shaft to force and the ring on. Good Luck. Oh by the way I got your tire here and waiting for you. /forums/images/icons/smile.gif
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    finally figured it out... used a big azz metal c-clamp... used the snap ring pliers to get the back side of the snap ring part way on the shaft... then cranked down the clamp until the ring was almost seated. This made the ends of the snap ring look tweaked... but a BFS (..screwdriver!) helped me pry them around the shaft and lock in place. now I just hope I got the bearings back in there right... cause I sure as hell never wanna take it off again! LOL!
    J
  10. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Jason,
    I have a big set of external snap ring pliars that I got from Sears that work great for that big snap ring. Hope this helps.
    Mike
  11. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Check my sig pics on the 205 rebuild. It will show the snapring pliers I used for those C-clips. They made opening/spreading those things a breeze (compared to the cuts, gouges, scrapes, I received when I tried using vice-grips, screwdrives, regular snap-ring plyers, etc on my first rebuild /forums/images/icons/blush.gif ). Having the right tool(s) sure makes a difference. I would have answered you post on the 205 "funny" shaped washer too, but I was on vacation FWIW it is in the correct position.
  12. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    awesome leadfoot, thanks for the confirmation on the washer. As far as having the right tools... yep, makes all the diff in the world. /forums/images/icons/wink.gif thanks again!
    J
  13. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I've been using some junky chinese snap ring pliars with interchangable ends to try and put the snap ring back in my steering box... its driving me to the edge of insanity :crazy:
  14. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    For large snap rings with no holes for snap ring pliers, wouldn't ring spreaders for putting rings on pistons work? The ones that go on the outside of something at least. Just a thought, I usually do stuff the hard way and gouge my fingers, but this thread got me thinking.
  15. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    would be simple to make a quit set of pliers for this and other stuff but you would need a little welder
    but could just make a real quick battery welder though
    hmm
    still crappy
  16. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    holy back-from-the-dead-threads batman! I posted this originally in 2002. lol! Good to see people are using the search feature... :thumb:
    j
  17. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    For anyone who's messing with these snaprings often...
    Snap-On SRP4 snapring pliers
    I used these extensively when I worked at the trans shop, and they're the bast way of dealing with the plain-C snaprings. Heavy truck transmissions are filled with those F'n things...
  18. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    cool beans. Someday when I'm rich I'll get some. $50 for one set of pliers is serious cash! :)
    j
  19. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Yeah, that's why I specified "often". I even looked on eBay for a while before I bought mine, no luck.
