GDF-ing Hubs Won't Engage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Aug 15, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    GDF-ing Hubs Won\'t Engage
    An International truck got stuck in one of my bosses fields today, i get hooked up to pull him out, throw it in 4 wheel drive, start moving and then my boss tells me the front tires arent moving. This is 2 days after id torn the hubs completly apart and put it back together, the front driveshaft spins and i know its getting the pinion because i tried it when i had it all apart and everything worked fine, I did a little search and came across this[ QUOTE ]
    the warn locking hubs need only a light smear of grease.
    if you pack them full you will get NO power to front wheels as it will hydraulic lock
    I choked those hubs with grease and im wondering if this is the cause. can anyone explain to me what hydro lock is and why it happens, Ive got Warn Premium Manual Internal Mount Hubs, If anyone has has a diagram of this type of hub in an exploded view i would very much appreciate it if you could send it my way. /forums/images/graemlins/1zhelp.gif
  2. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Re: GDF-ing Hubs Won\'t Engage
    Hydro lock - There is so much grease that it is not letting the hub engage... Turning the knob pushes the spring and pushes on the hub. With all the grease in their, it can't over come it and will not lock in. Take it apart and play with the hub and see how it operates...
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    pull the warn hubs out and clean almost all of the grease out of them.
    then stuff them back in.
    the grease is trapped in the hub preventing the sliding gear from engaging
