Gear change needed, keep 10blt OR swap the 44 in??? Opinions please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Apr 11, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    The 10bolt that is in the K5 right now has new U-joints, new tie rod ends, and all new ball joints. The dana44 I just got is all tight, but unknown age of any joints etc. Both have 3.07's and I need to swap 4.10's. What are the pro's, con's, interchangable items, cost comparison for gears, and strength issues. Thanks guys!!!
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Just keep the 10 bolt in. There is no real strength difference from a 10 bolt to a D44.
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Correct me if I'm wrong, but don't the earlier d44's have a thicker axle tube than a 10 bolt?
  4. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    The axles on the 44 are slightly larger (diameter=strength), and the housing looks a little beefier, but that would probably be it. I have a 44 now that I'm going to rebuild, but you won't gain a whole lot out of swapping a 10 bolt to a 44.
  5. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I would say keep the 10 bolt since you allready have it in your truck, and it has alot of new stuff on it.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Keep the 10 bolt. Case closed. /forums/images/icons/wink.gif
  7. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    wayne,
    i thought the newer 10 bolts were actually a bit stronger than the 44s...that is what a couple people told me, which influenced me to go 8 lug with my 10 bolt instead of swapping in a 44...
    Later
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Just look at the meat on the housing between the two and you'll see which one has a stronger housing.
    The axle shaft diameter is larger on the 44 and there are more splines on the 44 shafts.
    I wouldnt say it's enough to warrant swapping out the 10 for, but if you had a busted up 10, and a 44 fell into your lap I would definitely put the 44 in.
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If it were me, I would stay with the 10-bolt. The reasons are that you have already spent a decent amount of money putting new parts into it, plus used parts are much more common and typically cheaper (a lot of junkyards will try to tell you that a 44 is way better and therefore ask more money.....) for the 10-bolt. The Dana 44 has not been used in a GM truck since the late 70's so any used parts are over 20 years old.
  10. shoeless
    shoeless Registered Member
    Nov 1, 2001
    99
    N/A
    You can also keep your existing carrier with the 10B, the 44 will require a new carrier.
  11. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Keep your 10 bolt. you won't notice a strength difference. The late 80's 10B have 30 sline shafts and the older ones have 28 splines. That's why the newer ones are a little stronger.
