Gear change/Speedo
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TwoCrowsDesign, Mar 1, 2002.
  1. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I just swapped a 3.73 rear into my Blazer, replacing a 3.42. Of course now the speedo is whacked. I assume that when I go to larger tires the speedo will change again. Will 33's get me close to accurate? What will 35s do? Running 31's right now which were stock along with the 3.42 gears.
    Thanks,
    John
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    33"s will get you closest to stock.
    31/3.42 = 9.06
    31/3.73 = 8.31
    33/3.73 = 8.85
    35/3.73 = 9.3
    Thats how i look at it... you are getting most power with 31s and 3.73 of course and with 35s it will
    have less umph than stock though but your spedo wont be too far off... id settle with 33's.
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 6"susp, 35" BFG Muds, CatCo Cat & Series 40 delta flow 3" tips.
  3. TwoCrowsDesign
    Jul 13, 2001
    387
    Thanks, that makes sense. Hmmm, 4.11s huh?
    John
  4. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Just pick the size tire you want, then change the plastic gears in the transfer case. My parts guy printed out a list of all the gears with the color codes and tooth counts. The math sucks but its worth it for a accurate speedo. Cost me $3.20 for the drive gear, $7.60 for the driven gear and $20.29 for the sleeve for the driven gear when I switched to 4.56 and 33's about two years ago. I still got the printout let me know if you want a copy.
    Jim
    88 Jimmy, D60, 14Bolt FF, 700R4, NP241
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    <a target="_blank" href=http://www.tciauto.com/tech_info/speedo_gears.htm>Speedo gear info and formulas</a>
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
  6. TwoCrowsDesign
    Jul 13, 2001
    387
    Thanks, I'll tke a copy if its not too much trouble.
    John
  7. jimmy88
    Feb 17, 2002
    351
    Detroit, MI area
    Great link, don't forget to use the loaded diameter of the tire when you use the TCI calculator.
