gear change
Discussion in 'The Garage' started by eeyore, Mar 12, 2006.
  1. eeyore
    eeyore Registered Member
    Sep 18, 2005
    47
    utah
    i did a search but wanted to make sure.i have a dana 60 front carrier from a military truck.35 spline,track lok.4.56 gears.do i need a spacer to put 5.38s in ?it sounds like they will go right in.im very new at this any help is appreciated.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The 4.56 carrier is the higher ratio carrier so you should not need a spacer. The carrier break is 4.10 and down and 4.56 and up I believe.
    Harley
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Like Harley said, you should be good to go. :thumb:
  4. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    Hey eeyore what are you going to do with your 4.56 gears I really need some bag and are on a budjet.
  5. eeyore
    Sep 18, 2005
    47
    utah
    sorry junior-k5, im not changing them now.i just found out there are no 5.38s for the corporate 14 rear.if i end up doing something else and getting rid of them i will let you know,thanks
  6. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    cool thanks just thought I would ask.
