Gear Changes Due To 35's
Discussion in 'The Garage' started by 78GMC1/2TON4x4, Sep 15, 2003.
  1. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    Gear Changes Due To 35\'s
    would it be wise to change my stock 10 bolt gears to say 456's if i threw on some 35's? Or will i be fine? /forums/images/graemlins/truck.gif
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Re: Gear Changes Due To 35\'s
    What stock ratio do you have? If you have 3.42, 3.73, 4.10 then you should be ok. Hell I ran 35's with 3.08's for a long time. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  3. 78GMC1/2TON4x4
    Mar 10, 2003
    167
    Mount.Angel, OR
    i got 3.73's....thanks /forums/images/graemlins/truck.gif
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    if they are true 35's , you'll feel it in the gas pedal.NOthing terrible, IMHO. It will be slower off the line, and you'll put a bit more stress on your tranny, so be sure to do the usual cooler upgrades, temp gauge, etc.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't waste a dime on a rear 10 bolt. I'd consider changing a front, but definitely swap to a 14 bolt full floater in the rear before you even think of messing with your gears.
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    yeah, swap in a ff14b b4 u swap rear gears.
    afa the ratio, I want 5.13s so I can actually use my 700r4s OD. I run 35s onroad, 39.5s off. my 4.56s just arent low enough.
    j
  7. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    I'd go for the 4.56 with the 35s if you don't have the cash for a 14 bolt and you aren't beating the crap out of your rig. I started out with a 3.73 in my sub with 33s and I thought it was a doggggggggg. I couldn't use the OD on the highway until I got up to 85MPH. I am going to 35s on the next tire change.
    Tim
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    Here we come with the 1 ton SHeeple.... They tell you you should swap in a 14FF and dont even ask you how you wheel. I wheel pretty hard trying anything I can possibly think of and my 12 bolt is chugging along nicely.... I have had times on rocks where I have it full throttle with the frotn and rear bouncing up and down without breakage on 35x15.50 TSL's.
    So what type of terrain do you wheel?
  9. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    well, i tend to recommend ff14b swaps because the axle is dirt cheap and solves a lot of strength issues other axles have (translation: will cost less down the road too). I never said anything about doing a full 1-ton conversion... just the rear end. If this guy breaks an axle someday and his tire drops off 'cause he still has a SF axle.. he'll wish he had saved money and gone ff.
    j
