Gear drive small block chevy
Discussion in 'The Garage' started by slider, Jan 7, 2004.
  1. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Who has installed one? I did a search and only found one answer. I put one in my 383 stroker and it is about to come out. That thig is susposed to be the quiet version and it sounds like hell. Man that thing is noisy. Kinda sounds like a power steering pump thats about to blow up. Will it get quieter when the gears lap in? I will give it a day or two but this thing is loud. I was very careful when I put it in so I know its in right, Its real easy to install. I even degreed the cam. It sure runs good but damm. I won't have to worry about kids dogs or deer in the road I am sure they will run like hell when they here this thing. Any one else put one in and regret it?
  2. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    I had it in 2 different 350's and one 396 and had the Pete Jackson noisy in all of them and didn't mind it as my exhaust drowned it out. You do get used to the sound but also the brand makes a huge difference on how loud it is, have heard the cheap quiet ones be noisier then the Pete Jackson "quiet" gear drive.
  3. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Just tell people you got a blower /forums/images/graemlins/thumb.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I can't stand them. If you don't like the sound, you'll be removing it. They're not designed to be quiet. The noisier ones are simply cut in such a way to make them even louder. Either way, you should have never installed it if you didn't expect noise, but I'm sure nobody warned you of this before you put it in.
    I personally just run a good chain in everything.
  5. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    if u take it out and r lookin to get rid of it...drop me a line.
    NITRO
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I know someone that just had one grenade on him and it took the whole motor with it /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif Pm POWERMAD, he is the one.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Timing chains can do the same thing. Had a chain break at high RPM and lost the motor, (well every piston and valve that is.)
  8. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Thats why it's all about buying high quality double roller chain setups. Not the 19.95 systems from the parts houses. A good Cloyes or similar system will easily outlast the rest of the engine.
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I didn't build it, was in a car I bought. Must have romped on it to hard, no biggie, just a 305 anyways.
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Gear drive is bad for valve train. Do some research and I'll bet you'll find out the same thing.
  11. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Cheap as possible from the factory, nylon gear and crap chain. seen more than a few of those fail.
    They should come with a sticker... replace as soon as possible.
    As soon as it gets a lil warmer out I will be tearin down the plant in the 73 and post up what the damage is.
  12. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    How so? The space between the gears create to many bad harmonics? Does it wear faster? Curious minds want to know....
    I never thought about using one as a deer deterent. That seems to be a great idea, there are lots of those critters around here, I have hit/missed several....
    I bet that would work good in parking lots too. Might come in handy in court someday. Let the judge listen to it, and ask who in their right mind would walk out in front of that.... /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif (Do not take that the wrong way) /forums/images/graemlins/pimp1.gif
  13. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    They transmit harmonics from the crankshaft into the cam and valvetrain. Also the harmonics from the gear drive themselves. So you hit the nail right on the head.
  14. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I've had a Pete Jackson noisy gear drive in my 388 since I built it in '99. There are many who say that it transfers too much torsional vibration to the camshaft, but realisticly, this has never been proven. I have had nothing but good luck with mine, it will never stretch, lose nylon teeth etc etc. I am still using the same block, crank, cam, bearings, pistons, rods etc......no catastrophic failure from the "extra" vibration yet! /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/thinking.gif
    All of the gear drives that I've had experince with, through buddies and my own, have become less noisy the more you drive the vehicle. Mine is faintly audible with my 3" exhaust and 40 series Flowmasters. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  15. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    If you call that faintly audible, then what is your idea of LOUD???? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    I have heard his rig BTW.... /forums/images/graemlins/thumb.gif
  16. slider
    May 7, 2001
    547
    So as the gears lap in they will quiet down. Good I just drove it around the block and I think it is getting quieter. I wonder if the gears should have a break in period like a differential?
  17. slider
    May 7, 2001
    547
    Dude thats funny /forums/images/graemlins/grin.gif
  18. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yea...but you haven't heard it at WOT!! /forums/images/graemlins/eek.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  19. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Don't get me wrong, I like his 'Burb. When my motor is done, we will have to swap for 8 mins.... /forums/images/graemlins/pimp1.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif
  20. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Isn't that where it spends most of it's time at????????????????????????????????????????????????????????????????????? /forums/images/graemlins/eek.gif
