Gear drives
Discussion in 'The Garage' started by adamforsythe, Dec 3, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    When I rebuild the top end on my engine I was thinking about replacing the timing chain with a "Noisy" Gear Drives. How much of a whine would it make on a 350 with a good size cam?
    Adam
  2. wicked jester
    wicked jester 1/2 ton status
    Jan 8, 2004
    139
    CANADA
    They make plenty of noise, sound really kool but they transfer way to many harmonics to the cam shaft. A good double roller is by far a way better option.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    While many will tell you to avoid gear drives because they "transfer harmonics to the camshaft", that theory has never been proven. How does one explain the fact that many engines came with factory timing gears.....many GM straight 6's for example?
    I have been running a noisy gear drive in my 388 for over 6 years now. This engine is used hard and still runs strong even with all of the "nasty harmonics" :rolleyes: ;) :haha:
    Here is an old thread on the subject: Clicky
    If you want to hear my gear drive, you can down load this wheelin' clip.
    http://oldvertdog.homestead.com/files/Mud_hole.mpg
    :D :D :D
  4. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    Personally, I thought I was going to install that noisy gear drive.
    Until I pictured myself on the trail for 6 hours wishing I had not done it.
    Went with timing chain.
    Up to you. :D
  5. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    My buddy had a 71 Chevy shortbed years ago we put one in and it was cool to listen to that thing.. We would pull hole shots for hours just so we could hear it and get it ready for the track :cool: His other truck blew the motor and he started DD the 71.. After a while he said the noise from the gear drive was getting annoying, so we fixed his other truck.. Now keep in mind he loved to ride in and listen to it for hours until he had to drive it everyday.. So that's something to think about if you're going to use it as a DD..
  6. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    when i get a cam for mine i plan on doing that gear drive i would rather gear then a chain
  7. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    I've got a built 454 with a Pete Jackson "Noisy" gear drive. I love it. I don't get annoyed by the noise at all. Of course it makes plenty of noise anyways with long tube headers, dual 2.5" exhaust with no crossover, and Flowmaster 40s, let alone the 40" Boggers.
    Bottom line is you can hear it whine. I think it sounds cool. I like the fact that it would be nearly impossible to break it, or for it to lose cam timing somehow. That alone is worth the gear drive to me.
    Get one!
  8. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I have one for sale (hardly used) if you're intersted. $50 shipped
  9. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    if fuel injection it will mess with the nock sensor.
    my friend has a noisy in a 63sbstep side. stight headers. you can still hear it. i had a quiet in my truck. was just right for me.
  10. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    quite possibly does that require a different timing cover?
  11. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    AFAIK...Never been proven one way or the other. This is one of those topics where the opinoins fly without proof. Don't believe everything you read.
    I'll be the first to admit that i have not tried it and i have no idea what would happen.
    Read up on ThirdGen and you will find that some of the TBI and TPI guys over there run them successfully.
  12. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    IIRC it will fit under the same timing cover as a chain. I think...
  13. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    yeah that is what would be make or break for me
  14. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    The Pete Jackson types fit under the stock cover....
  15. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    I have noticed that some manufacturers say "some machining may be required". What exactly needs to be machined, or can it be fitted with a dremel or grinder?
  16. sweetk30
    Nov 1, 2004
    25,547
    542
    the ideler gears have a stub on the back side to ride agains the block. thay need to be ground to set the depth of the gears to the main gears. easy to do.
  17. Shawn
    1,753
    5
    5280'
    No, fits under stock timing cover. Looks like a Pete Jackson.
  18. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    hmm if you got it in a few weeks i just might how loud is it and how worn >?
  19. 88trailblazer
    88trailblazer 1/2 ton status
    Apr 11, 2004
    425
    Miami, Florida
    I have a "quiet" gear drive on my 78k10. The sound is noticable but not unbearable. Sounds like a honda in reverse. :D No complaints so far though.
  20. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I just installed a noisy gear drive in my new built SB350 and with the radio going, and the 40 series flowmasters and headers, and tires, the gear drive is hardly noticable.
