gear help
Discussion in 'The Garage' started by dave_90_blazer, Jan 24, 2004.
  1. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    ok, I plan on getting some 38's(maybe a little bigger down the roadf, 40 maybe) when i go D60/14bff, right now i have 35's on 10b/10b
    i was wondering what gear ratio would work best for me w/38's?
    also, what lift should i think about?, it has 4" (frt spring, rr blocks) now
    ohh, 355, near 390-400hp, 700r4, 231 (i think , need to double check)
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    NP 241 is what you should have. Anyhow go with 4:88's or with the od trans and 38's or 40's. You could probably go with 5:13's too.
  3. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    5.13's would be perfect with the 700R4 and 38's.
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    4.88 if your conservative
    5.13 if your aggresive
