Gear identification
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Sep 8, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Well I am pretty sure the axles are the origionals on my 89. Does anybody know the code for gears in an 89. I will be selling them soon and don't want to open them up untill they are out.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  2. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    go to www.4lo.com it tell you there
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  3. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Oopps... screwed up this post, see the one below.<P ID="edit"><FONT class="small">Edited by CV202 on 09/08/01 09:04 PM.</FONT></P>
  4. CV202
    Nov 14, 2000
    454
    Kingfield, ME
    On some axles there's a tag riveted to the pumpkin that has the ratio stamped into it. It will either be traditional 3.73:1 or 41:11 (same thing) this will designate what orginally came in that axle, not necessarily what's in there now. There's also a way to tell be comparing revolutions of the driveshaft to the revoultions of the tire. (i.e 4 revolutions of the driveshaft to 1 of the tire equal 4:1) Check my math though, my brains cramping. Good luck.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  5. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    OK the tag is not on the axle, and I am looking for the code that would be on the tag in the glovebox.
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Here you go, brother:
    GU4- 3.08
    GU5- 3.23
    GU6- 3.42
    GT4 or 5X1- 3.73
    GT5 or GT8 - 4.10
    G80- Limted Slip
    Hope that helps!!!
    <font color=blue> MEAN DAD WITH TWO BAD KIDS<font color=blue>
  7. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    are the axles still on the truck? if so have someone watch the driveshaft and someone watch the valve stem on the rim. one rev on the rim to how many on the drive line. 3 3/4 turns on the drivshaft should be 3:73s little past 4 would be 4:10s or 4:11s. hope this helps.
    <font color=blue>whats a 4 letter word for farm wagon?-- ford</font color=blue> [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/slider79blazer>http://community.webshots.com/user/slider79blazer</a>
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Thanks brother, here is what I got:
    GU6- 3:42's
    G80- which I assume is the gov-lock.
  9. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Anybody ever seen a Blazer or Pickup with 3.23 gears?
    Lift It, Lock It, LIVE IT!!!
  10. dyeager535
    26,979
    Where have you heard/seen this? The limited slip tag is bolted to the diff cover using one of its bolts, but the axle code AFAIK, has ALWAYS (since the 60's) been stamped into the passenger side axle tube, facing forward as installed in the vehicle.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  11. dyeager535
    26,979
    No I have not...but I know that some of the big cars (10 bolt rears) in the 80's got 3.23's, and they may donate them to my truck, instead of 3.42's that are in it now : )
    Dorian
  12. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Ya, I'd like to know abiut this tag riveted to the pumkin too !
  13. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    I've seen Fords I know with a little aluminum tag attached thru one of the bolts on the 8.8s diffy cover. Don't know about remembering a GM with it. Not to say they haven't had em.
    Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
  14. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK... I dont have any of those id's... on the drivers side of the rear 12 bolt it says "GM84" and on the passenger side it says "3896839" I donno what it is??? It's a 78 with a dana 44 front... HELP!!!
    [image]http://www.inhomenetworking.com/images/littleblue.jpg[/image]See me at <a target="_blank" href=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</a>
  15. flblazer
    Nov 24, 2000
    149
    tampa fl
    go to www.4lo.com
  16. reddog64
    Nov 9, 2000
    3,325
    i went to 4lo.com... didnt help... couldnt get anywhere helpful...
  17. Executioner
    Feb 22, 2000
    1,530
    Your not looking in the right place, try this stamped into the passenger side axle
    tube, facing upward (toward the sky) as installed in the vehicle.
    Good luck
  18. reddog64
    Nov 9, 2000
    3,325
    thanks I'll check tonight!
