Gear Indicator hook up to Steering Column
Discussion in 'The Garage' started by BEHJR, Jul 19, 2003.
  1. BEHJR
    BEHJR 1/2 ton status
    Mar 28, 2003
    141
    Plano Tx USA
    '75 K5
    Took the dash apart to see how to fix the gear indicator on the steering column. I cannot see how it is linked to the steering column that rotates as you change gears (P to R or the Ds). Since my Chiltons does not go into that detail, I have no clue. There is evidence of southern engineering and I am wondering if I am missing a part. Anyone with a service manual or knowledge of a '75 dash --- HELP !!
    The red indicator is there with the spring that moves it to the left, but no hook up to the steering column is apparent. There is a piece of string or filament that looks broken, but I am assuming the is from PO. Also if you have a service manual that gets into this kind of detail, I would sure like to know what it is, so I can get one....
    Maybe the LMC catalogue has a pic. I have ordered 3 I think, and have yet to receive one.
    Thanks.
    BH.
    /forums/images/graemlins/1zhelp.gif
  2. Xtreme Off-Road
    Xtreme Off-Road Registered Member
    Apr 27, 2003
    48
    Ontario, Canada
    The piece of string is what moves the indicator. If you pull on the piece that is hanging out of the dash, the indicator should move. The end of that string would normally be attached to the edge of your steering colomn with a clip.
  3. BEHJR
    Mar 28, 2003
    141
    Plano Tx USA
    Then I guess I am missing the clip. Any idea what it looks like and where it is attached ? /forums/images/graemlins/ears.gif
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i think for just the clip you might have to hit a scrap yard..or make one..
  5. Xtreme Off-Road
    Apr 27, 2003
    48
    Ontario, Canada
    It kinda looks like one of those clip-nuts and it attaches to the edge of the steering column that moves with your shifter.
  6. BEHJR
    Mar 28, 2003
    141
    Plano Tx USA
    Are you looking in a manual ?? If so which one.
    I appreciate your help. Maybe one of the auto parts store has a pic. I sure cannot find one.
    BH.
    BH.
  7. Xtreme Off-Road
    Apr 27, 2003
    48
    Ontario, Canada
    This is all from memory. I have taken apart my dash enough times. Have you ever seen the little clip nuts that come with new speakers. You could just tie the string to it and clip it somewhere around the bottom half of your column.
  8. BEHJR
    Mar 28, 2003
    141
    Plano Tx USA
    There is a L shaped gizmo sticking out from the column that looks like it is about in the right position. However, there is no hole in it for the string to go through. Is this what you are talking about. Maybe a clip or something is missing from that. I cannot believe it is string attached. LOL. Talk about cheap.
    I have no clue about the speaker clips you are talking about. I am sure these are the same on PUs as well. I guess my first trip to the junk yard is in order. Maybe wait a while and grow a shopping list.
    Thanks again.
    BH.
  9. Xtreme Off-Road
    Apr 27, 2003
    48
    Ontario, Canada
    It sounds like you found the right clip. You can take it off the column by getting under it with a small screwdriver and pushing it towards the firewall.
  10. BEHJR
    Mar 28, 2003
    141
    Plano Tx USA
    Anybody parting out a 75-78, let me know. Put it in parts wanted as well. Seem to be the same for a number of yrs.
    Thanks.
    BH.
  11. DUKSRULE
    DUKSRULE 1/2 ton status
    Nov 25, 2001
    303
    Va Beach Va
    You can use a spring type paper clip too. Not a normal on but the kind that is black and shaped like a triangle and then has the 2 metal arms to make it open. You can squeeze the arms and remove thme from the clip. Tie a piece of string around one of the small ones and then take the arms off and slide it onto the column. If your column still has the clip on it just pull it off and rap some string around it then push it back on. It is pretty simple. You can get the paper clips at Walmart or something like that.
