Gear Indicator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Oct 7, 2002.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    After my lift was put on i noticed that the gear shift indicator stopped working does anyone know how i can fix this? /forums/images/graemlins/thumb.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Did you have a body lift?
    Did you extend the shifter linkage? if not you will have that problem.
    IceMan
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Mine had a little teeny tiny piece of string that went from the column to the orange pointer. It used to fall off or come off track ALL the time. Its not too hard to fix.
  4. Me89'Jimmy
    Oct 6, 2002
    127
    Sykesville, MD
    I had a body lift put on and i didnt extend the linkage
    so how can i fix it?
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    You basically want to extend the linkage as much as you lifted the body, the indicator would point at the right place.
    At least thatis what I did.
    Mine is a 76 though I am not sure if yours is the same
    IceMan
