gear install question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dbltapp, Aug 24, 2001.
  1. dbltapp
    dbltapp 1/2 ton status
    Apr 25, 2001
    133
    Maine, but moving again.
    i am having 4.10's put in my 10 bolt(i know,i know!) and the mechanic is telling me that it is going to take almost twice as long to do the front then the back. does that sound right? the axles are out of an 86 blazer.
    "Luck, often enough will save a man, if his courage holds"
    89 SUBURBAN, 1/2 TON, 350 TBI,21/2 LIFT W/33'S
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I was told that it would take 1 hour more for the front. This is because removing the rear is easy and the front has some additional stuff (steering components). I was told 4.5 hours for the rear and 5.5 for the front. So, I am doing mine myself tonight!
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Who put a stop payment on my reality check?!?
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    To even get the diff out of the front housing requires you to first remove:
    Wheels
    Brake calipers
    Locking hubs
    Outer wheel bearings
    Hub/rotor assemblies
    Spindles
    Now you can finally pull the axleshafts out of the housing. [​IMG]
    So yes, it is a lot more work to do the front than the rear.
  4. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Ditto to what HarryH3 said. In OKC it will run you about $350 for the front and $250 for the rear.
  5. dbltapp
    Apr 25, 2001
    133
    thanx guys!
