gear install?????
Discussion in 'The Garage' started by 85mudblazin, Jun 2, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am looking to put in 4.10 gears front and rear and i was wondering if I need anything else besides the ring and pinion, I have seen these gear install kits and such things like that, do I really need one? Also where is a good place to get gears cheap that are of good quality?
    Thanks /forums/images/graemlins/thumb.gif
  2. cuzinjay
    cuzinjay Registered Member
    Feb 13, 2004
    62
    rome ny
    The install kits do have things you will need in them seals, pinon nut ,marking compound ,shims and such.
    If you are wanting to save some coin I wounld check the local boneyards for a 3/4 ton with 4.10 in it.
    The yard I work in sells them for 75 to a 100 dollars a piece. Just picked up a d60 my self for 50 after my discount.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yeah you are right I may as well not waste the money for gears when I am going to be swaping in the 3/4 ton.
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I have only done one gear swap in a Mustang 8.8"
    I wished I had bought the shim kit when I did it.
    It took me a long time and lots of reading to get it right
    I used a fact. service man. for the set up info.
    This can be a major PIA to do if you are not mech. inclined
    /forums/images/graemlins/dunno.gif
