gear install
Discussion in 'The Garage' started by chiefheaphy, Apr 15, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    what are the biggest issues that a fisrt time gear and detroit locker installer may run into. special tools that are required? Can I use a thick 5.13 gear on a 4.10 and down detroit lockr?
    thanks
    If I'm building a non-daily driver mudder, That my take the ocasionally trip through town for showoff purposes could I save myself some money n weld the spiders? If so, how?
    Thanks guys
    couldnt do it without ya.
    B
  2. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    detroit lockers for the 14bolt are all the same. it's the carrier that differs. you can drop any detroit in any carrier, then the carrier must match the cut of gears. the 4.10 carrier, i believe is ok for 5.13 regualr gears, i think it's 3.73 and down that you have to worry about. i might be wrong with that too.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    If you have a FF 14 bolt, you can only install a detroit into an open carrier. The gov-lok has a different carrier and will not accept a detroit.
    As for the gears, read here:
    http://www.pirate4x4.com/articles/tech/billavista/Gear_Setup
    Setting up gears isn't terribly difficult but can be tedious and slow. If you decide to tackle it, expect to spend a fair amount of time (for your first time setting up gears) and money (the tools you need aren't cheap).
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
  5. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    With the 4.10 carrier you still have to use the thick 5.13's
