Gear limitations with a Dana 70 SRW '90 Dodge rear end
Discussion in 'The Garage' started by mountainexplorer, Apr 18, 2005.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I've heard there are some undesirable characteristics/limitations to the Dana 70 rears that came under Dodge Cummins trucks. What's the good and bad about these sort of Dana 70's?
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    AFAIK, the only D70 there is an issue with is the one that came with 3.07's in the CTD trucks. From what I've heard a D70 with 3.07's will not accept any other ratio.
  3. mountainexplorer
    Nov 14, 2001
    4,903
    This one has 3.54 gears. So, most other Dana 70 internals are interchangable?
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    It all depends on the pinion offset if regular gears will interchange easily . There are still ways around it if it is one of those Dana 61 wanabe Dana70's .
    Eventhough it has common 3.54 gears it still might have the odd offset so becareful if you go to buy gears.
    The only other thing I can think of is that it should have 32 spline shafts instead of 35 spline stuff.
    Tom
