Gear Lube in your NV4500
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer72, Jan 17, 2002.
  1. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Does every one with a NV4500 run the GM lube or has any one tried some other than it?
    72 Blazer 400TPI NV4500 NP203/205, 6 bolt FF14
    01 Suburban 8100 2500 4X4
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    It is important to run the correct fluid in the 4500, otherwise the syncros will wear out prematurely. The cheapest place I know of to get it is Standard Trans, ~$56/gallon (?) (I think it holds a gallon.) Or you can get raped for it at the local Chevy/Dodge dealer.
    For more 4500 lube discussion than you ever wanted to hear, try searching on the tdr forums (<a target="_blank" href=http://www.tdr1.com>www.tdr1.com</a>).
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. blazer72
    Apr 13, 2000
    939
    KCMO
    I know this is what is said but the local shop that rebuilds them is not useing this any more just GL5 say that its a better lube than the gl4 that was used new, and yes they are a New Venture rebuilder.
  4. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    GL5 will eat the syncros and is specifically NOT recommended for the 4500.
    Pete
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    So much of my dreams of mud bogging with an NV 4500. You can bet I'm not getting water in $60 worth of lube.
    Tim
  6. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    The syncho's use some sort of composite fibre rather than brass...the GL5 eats that fibre stuff.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  7. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I have used NAPA synthetic 75-90 lube since using the NV4500. I called New Venture and spoke with their tech dept. When I asked if NAPA's lube would be OK, I was told that it would do all that GM's and Dodge's would do. I asked again if it was OK to use and his reply was "it meets all of NV's requirements but we can't authorize it". I will continue to use it, about half the price of GM's.
    87 K5, 427BBC,D60 & 14BFF, NV4500, NP208, TSM disc's,
  8. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    (note: this is a legit question, not a flame [​IMG])
    How often do you guys (ie the manual trans mud runners) generally change your fluid? I don't even take apart my hubs after going through water, let alone worry about the trans (auto). I did have a friend that turned his trans (727) fluid into a strawberry milkshake looking concoction out in Moab though after getting a little too deep with no extended breather hose on the tranny.
    Pete
  9. blazer72
    Apr 13, 2000
    939
    KCMO
    60 A CHANGE GUESS AGAIN 5.5 QUARTS AT 18.95 EACH FOR THE 4500, CANT TRUST THE SEAL TO THE 203 SO IT GETS 2.5 QUARTS AND THE 204 GET ANOTHER 2.5 OR SO. THATS ABOUT 11 QUARTS AT 19.00 EACH.
    I KNOW WHAT THE BOOKS SAY ABOUT GL5 BUT THE REBUILDER WHICH IS A NV DEALER USESES IT.
  10. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Is the 4500/203 seal setup much different than the OE 4500/241 setup? Factory they run atf in the t-case and gear lube in the tranny. Feel free to run WD-40 in your trans if you want, I know what's going in mine, though. [​IMG]
    Pete
  11. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Pete, I change my tranny oil about every two years...or whenever something breaks and it comes apart anyways.[​IMG]
    Rene
  12. blazer72
    Apr 13, 2000
    939
    KCMO
    The seal on the 241 is really 2 seals in one, the 203 uses a singel lip seal. I dont think that the WD-40 would work or were you being nasty.... It does not hurt the lube in the 4500 much if it gets atf in it. But the oil that the 4500 runs will not mix with normal 80w90 it truns to goo.
