Gear Manufacturers
Discussion in 'The Garage' started by ntx78k5, Jun 24, 2005.
  1. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    Did a search and didnt find exactly what I am looking for. I am about to have a gear swap done and want to know which manufacturer offers the best bang for the buck?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    There are a few to stay away from as far as quality goes. You cant go wrong with: Richmond, Precision, Yukon, Superior...
    :thumb:
  3. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    Thanks for the info.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
  5. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    I'd look for used... that's the best bang for your buck! :p:
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Stay away from Genune Gear...my opinion is they are potmetal crap...
    .02c
  7. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    :D That's a purty engine burt!
  8. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    Not knowing what to look for. What are signs of problems with a used gear set other than missing teeth?
  9. Burt4x4
    6,854
  10. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    Wow... nice and clean engine! As far as the gears go... look for missing teeth, grooves, and when you drain the oil... look for foreign material, if the oil's pretty nice, and you can turn the gears over no problem... then you should be good. But look for your standard chips and cracks!
  11. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    yeah, avoid genuine gear, they suck. Yukon, precision, richmond... they are all purdy good. Superiors are bling if you wanna spend the extra $.
    j
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    What ratio are you looking for and for what axles?
  13. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i surprised no one said Motive Gear?
  14. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes Genuine Gear is crap. Sierra and U.S. Gear is good too, along with OEM sets.
  15. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I personally would stay away from Yukon's. They are specific to Randy's Ring & Pinion. They are cheaper than alot, but you never know what you are gonna get. He contracts all over & they may be Canadian steel, Mexican, US, etc. Very inconsistant.
    Just my opinion - which was actually asked for :grin:
  16. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am running Yukon gears front and rear. They have held up so far and they were easy to set up. They are a good price also :xmas:
  17. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    411 or 456, Dana 44 up front and a 12 bolt in the rear on a 78K5 full time 4x4
  18. Emmettology 101
    May 9, 2000
    8,126
    FL
    I've heard that Yukon and Precision are made by the same company. But Precisions are better quality, hence they are more $$$..... I called Precision(tech# on their website) not long ago to ask a question about my Precision D60 gears and the number went to Reider Racing in MI.... So I think Randy's is either just a Yukon Dist for Reider or they are in cahoots....
    NTX78K5 - sorry cant help ya there... I have some 4.10's for a 14FF.... When looking at used gears.. Check the tooth condition and make sure it has a good wear pattern.... :thumb: You're probably just better off buying new!
  19. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    I remember awhile back when this was the common view over on pirate... but since then it seems that people have for the most part been happy with Yukons. There is definitely negative opinons on genuine gears... but not many people post up "i blew up my yukon gears!!!" over there... and those throttle jockets can break ANYTHING.
    j
  20. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    411 Dana 44 front 12 bolt rear, currently have 342's
