Gear Marking Compound
Discussion in 'The Garage' started by or2play, Jan 19, 2004.
  1. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Okay, trying to finish the gears in my 14 bolt. The little bit of marking compound I had got used up. I've tried red grease. But everytime I've ran a pattern it all looks like goo to me. What do ya'll use in the when marking compound isn't availabe?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    You pretty much have to use marking compound. I've heard of people using the blue stuff that machinists use, but I wouldn't use it on my gears.
  3. fly_n_hi_yukon
    fly_n_hi_yukon Registered Member
    Jul 8, 2003
    44
    Strange Range, MI
    I used Loctite machinist blue compound. Worked great. The pattern was clear as day.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Get some more compound! If theres a little left, add a little water, it doesnt take that much to repaint the teeth to recheck the pattern. /forums/images/graemlins/thumb.gif
  5. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    i've heard you can use a sheet of paper... maybe i'm on crack.
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Sounds like. /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
  7. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    i used toothpaste once in a pinch and it wasnt to bad, just dont use the gel stuff, i dont think it would work.
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I usually just use compound, But, once in a pince, I used white lithium grease. It worked.
  9. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Go by your local GM dealer and use actual gear marking compound . They sell it in little tooth paste looking tubes . Tom
  10. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    I snagged some more from my supplier. He stole it from a kit, but it was different than the stuff I had before. Actually it looks like white litium grease. We see how it works I couple days I guess.
  11. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    Did it leave your gear teeth clean, and your oil with a minty fresh smell? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
    Does that prevent differential tooth decay? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Sorry, just joking, I couldn't resist /forums/images/graemlins/grin.gif
