Gear Oil change question>>
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burt4x4, Jul 3, 2001.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey gang, as most of you may know I just put in new R&P front and back.
    I am also going to Blazer-Fest next week.
    My rear has about 50miles on it and the front has about 15.
    Should I replace the rear gear oil before the trip or just don't worry about it until after????
    Also, I am running the HDuty suff that is like 140wt instead of 90wt that also has the limmited slip additive allready mixed in the oil. Is that enough additive or should I get a bottle of stink and add that to the mix also?????
    Thanks for your thoughts!
    <A target="_blank" HREF=http://www.geocities.com/baja/5099>http://www.geocities.com/baja/5099</A>
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The instructions that came with my ring and pinion suggested changing the gear lube after 500 miles. Of course, 500 miles with the hubs unlocked won't put any wear on the front gears. [​IMG]
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Considering you've done some major work there, I'd change it before and after. It can't hurt, and what does a few quarts of gear oil cost??? Strain the old stuff through some old pantyhose to catch any chips that may come out, and take a good look at them to see if any are "Oh God, it's all coming apart" -sized.
    If at first you don't succeed, failure may be your style...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  4. Burt4x4
    6,854
    Ya I know the 500 mile thing too but was just worried about the 'break-in' metal flakes that get in the oil. I wonder if that will do any harm when wheelin. I plan on being light footed with the throttle because the R&Ps are new anyway so......
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    How far of a drive is it for you to get to blazer fest?
    If first you dont suceed......GETA BIGGER HAMMER!! [​IMG][​IMG]
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  6. Burt4x4
    6,854
    Hmm 2hrs or so.......
    Just checked mapquest it is 100 miles one way....
    <P ID="edit"><FONT SIZE=-1>Edited by Burt4x4 on 07/03/01 10:47 AM (server time).</FONT></P>
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I'd go with what you have and change it when you get back.
    IF not, do the rear only. How long is it going to take you to put 500 on the front?[​IMG]
  8. Burt4x4
    6,854
    Well now that I have been told the gear oil I am using is crap I will change both anyway...
    I better doit to be safe instead of sorry!! I have way too much work into my gearing to take a chance on sh!tty gearoil breaking down on me and buring my R&P!!! or worse......
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    10-4
