Gear oil, How Much?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Sep 7, 2002.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    How many quarts of gear oil should a 14bff take? Normally/Roughly?
    Also, how many quarts would you expect a 14bff with "thick" 4.56 gears to take?
    I got a little under 3 quarts in. Does this sound right? Thanks
    Harley
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    IIRC, I would say that sounds correct. I've got the regular 4.10's too... Just keep putting it in there til you can't keep it in anymore... I use the cap on the oil container to plug the hole in the housing so I can fill a little beyond capacity... because some is going to leak out anywho, so I try to get ahead of it! /forums/images/icons/wink.gif
    -Dan
