Gear oil yellow???
Discussion in 'The Garage' started by mudbog42, Dec 9, 2006.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    This may be a rookie question but popped the check plug off of my front differential and real thick yellow fluid just started pouring out.:eek1:
    Is there yellow fluid or is this bad? Also I thought that the fluid level should be just under the plug:doah:
    Thoughts:thinking:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Holy crap you have a yellow overflow situation..................!!
    Nope that is normal. Once the G80-90 get spun around it gets a litte more yellow from the air bubbles in it. And having too much in the diff is not a big deal.
  3. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    Was it kind of gewy. You could of got mud and water in your dif.
  4. readymix
    May 30, 2004
    6,706
    26
    This is what water and mud look like in a diff.....
  5. JohnDeere
    Jan 17, 2006
    342
    Houston, Texas
    Dam thats bad I had some in mine but it was just enough to mix with the oil and change color to a yellow-brown.
  6. mudbog42
    Jul 16, 2006
    452
    Florida for now
    It was just really thick and yellow but didn't look like it had any brown in it
  7. readymix
    May 30, 2004
    6,706
    26
    I am sure it was fine
  8. jfaulk
    jfaulk Registered Member
    Dec 3, 2006
    60
    NC
    i drained my front diff today and i got the same yellow gooey stuff. either it's ok or we both got the same problem.:D
  9. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    gear oil and rtv are cheap. pop the cover and reseal it. add all new gear oil. never hurts. who knows how long the oil in there has been in there.
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If you checked it when it was hot that would account for the spilling out as the oil when hot expands. The oil will also be airated if checked after just having driven it so that would make it appear yellow in color.
  11. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Hollywood needs a clue, Creature from the Green Lagoon.:haha:
  12. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Tanks for all the help
    How often do you guys change your gear oil?:bow:
    Mines been in for about 3 years now when I did the gear swap:D
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Mine was in for 4 years until i recently swapped on new diff covers and the oil looked just like the day i put it in and also smelled the same too.
