gear oil
Discussion in 'The Garage' started by ftcjimmy, May 10, 2005.
  1. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    how much oil do i need to fill my 14 bolt (sf)? thanks
  2. dyeager535
    26,982
    191
    Mine took about 2 quarts when I filled it Friday, but that's a rough estimate, as I was half filling 1 quart bottles from an open 1 gallon container. :)
    My pinion is also sitting up high enough that I'm going to re-check fluid level and see if any went into the axle tubes though.
  3. ftcjimmy
    Mar 9, 2005
    61
    ct
    thanks
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I think it calls for 2 quarts- Might be more than 2, but less than 3. My mind tells me 2.5 quarts...
  5. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    ALL-DATA says 2.6 quarts, but I serviced mine yesterday and it took a whole gallon. I bought a gallon jug of 80w90 and a pump to go on it, the pump was sucking air when the oil started running out of the hole.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    humm i have always heard at least a gallon,
    mine with Kidjethro's rockin ass cover now takes 5 quarts :D
    and if you want to be real anal, jack up each tire to make shure oil getts into the hub
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine takes right at a gallon to fill.
