Gear Oil
Discussion in 'The Garage' started by CHEVY 4WD, Feb 2, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    How much gear oil do you put in the front 10bolt? and can you overfill it?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There is a fill hole on the front diff cover. It should be about 1/2 or 2/3 of the way up. Pull the plug, and fill with oil on flat ground until oil starts to run out the hole. Once oil runs out the hole put the plug back in. You could overfill it if you did it with the trucks assend on a downward slope. Fill it on flat ground till oil comes out. Its that simple.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Just over 2 quarts. You cant really overfill it because it will come out of the fill plug. You pull the plug out, fill it until it starts to come out of the hole, then put the plug back in.
    Dan /forums/images/graemlins/burb.gif
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Ok thanx I was thinking if more was better i could hold the bottel up close to it and squeez it then stick the plug in fast but if thats a bad idea then im not gonna do that.
