gear oill leaking out of yoke
Discussion in 'The Garage' started by wraenking, Feb 2, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    hey guys. i thought i was re doing the diff cover today only to find that the gear oil looks to be be coming out of the toke. i just installes the dana 44, so am i fuked?
    any fixes?
    thanks
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Did you put any sealant on the pinion shaft splines before you installed the yoke? If not, gear oil can seep along them and leak out the center of the yoke. :eek:
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    the yoke was already attatched, so im hopiung its just the seal?
  4. dyeager535
    26,977
    Is the yoke tight? If it's loose, it will ruin the seal and it will leak.
  5. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Is the leak coming from the pinion seal or through the center of the yoke (where the nut is)?
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Take it to a rear end shop, they can replace the seal for a suprisingly low price. It is a simple job for the seasoned rear end guy.
  7. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    the seal takes 5 mins to replace, i did mine...use some thread lock on the nut when yer done...so it doesn' get loose again.
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I don't know about a D44 but on a 14BFF the nut torque on the yoke places the crag on the pinion bearings, too tight and it will short live the bearings, too loose and it will slide around inside the races and ring gear. I would have it done by someone that knows what they are doing if in fact that is how a 44 works too.
