gear question
Discussion in 'The Garage' started by ShitownK5er, Apr 22, 2004.
  1. ShitownK5er
    ShitownK5er 1/2 ton status
    Nov 7, 2000
    121
    Shillington Pa
    Anyone know what gears i have in the 14 bolt 41 on the ring gear and 10 on the pinion gear?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    4.10's , Good ratio for 35-37's if you run an automatic /forums/images/graemlins/k5.gif
    4.56 would be better , but depends on your budget /forums/images/graemlins/waytogo.gif
  4. ShitownK5er
    Nov 7, 2000
    121
    Shillington Pa
    cool thanks guys 38s to big for em?
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    What transmission are you running?
    If you are running a 700R4 I would never use OD with 38's. You will burn up your tranny in nothing flat in OD. If you run a TH350 or TH400 then it is ok. I would still like a lower gear for those meats though. But it all depends on the $ available.
    Harley
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I just read your bio. It says 700R4. I would NOT run 38's with 4.10's. OD is out of the question if you do. I run 4.56's and 35's with my 700R4 and I want more gear. With 38's and OD you need 4.88's or 5.13 gears.
    My 700R4 was built to have a low stall speed and be heavy duty. I won't shift into OD unless I am doing 55mph or better with 35's that only measure 33.5". With a 38 I would never have enough RPM to shift into OD. And even if you did I doubt seriously if a 305 is going to have the balls to keep those tires moving on anything beside flat ground or down hills. My transmission hunts for gears enough with the 4.56's and 35's.
    Harley
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    An easy way to find out is divide the ring gear number by the pinion gear number. 41/10 = 4.10
  8. ShitownK5er
    Nov 7, 2000
    121
    Shillington Pa
    i think ill get 4.56 i have a th400 to put in backed by a np205. I evenytally want to run 39.5s with a dana 60 front. Right now i think ill just run the 4.10s till i get money to re-gear this summer thanks for all the input /forums/images/graemlins/weld.gif
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Check out 4lo.com and they have a gear calculator so you can figure out what gears would be best with what tire size. It is easy. Just find the gears that give you the right RPM at cruise and that is what you need.
    Harley
  10. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    hello american freak 86. I was reading your want add for the TH400 and adaptor for the NP203. Sorry to post out of the subject, I couldn't reply there because I am not currently a paid member of CK5. I have a whole setup (TH400/NP203 w/adaptor) if your interested. Or maybe we could work something out if you want me to remove the 203 or just the chainbox and diff to save on shipping or something. It is already crated up and ready to go. Everything is there, but the trans might need a rebuild, not sure. pulled it out of a truck that didn't run. If you're interested pm me with your e-mail address. I can't write PMs either.
    Thank you
  11. folkenheath
    Nov 12, 2004
    4,269
    159
    Wisconsin
    americanfreak86
    ttt, I'll be back to check tomorrow. Thanks again.
