Gear Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Feb 28, 2002.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ok, will a set of gears for a rear 10 bolt from an 89 work in a front from an 85? I am pretty sure the answer is yes, but want to double check. I know they had changed to the 30 spline carrier in 89, and want to make sure they didn't change the gears in any way. Thanks
    My Chevy isn't broken, its just out of gas.
  2. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Can someone help me out here? I got a line on a set of gears, but need to know this info first. Thanks
    Harley
    My Chevy isn't broken, its just out of gas. <a target="_blank" href=http://coloradok5.com/gallery/albuo73>My K5</a>
  3. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    only change i know of is the 28-30 spline in 89. i have an old 10 bolt 28 spline in the rear and a 89 30 spline in the front, and when i ordered my new gears about a year ago they were the same according to randy's ring and pinion. and i just ordered new yukon axles for the rear and stayed with the 28 cause my lockrite is a 28 spline.
    anybody else?
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
