GEAR QUESTION
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TB2Blazer, May 12, 2003.
  1. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    How can I find out what gear ratio I am running in my 85 K5. I've got a 14ff that I am going to put in the rear of my blazer that came from an 85 sub but I don't know the gear ratio in either of them.
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Yank the cover and count the teeth on the ring and pinion. The other way is to jack up the rear end, mark the pinion yoke and tire, turn the tire 1 full turn and count how many times the yoke turns.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> There was a tag inder one of the diff cover bolts when the truck left the factory, that's the easiest way if they're still there. The tooth counts are also stamped on the edge of the ring gear. The stamp is generally the most accurate way to find out the ratio.</font>
  4. dyeager535
    26,980
    I think they stopped using the tags in the 70's. Have never seen mention of them in the 80's service manuals. Only tag I've seen are the "limited slip diff" tags.
    Gear ratio code is stamped into the passenger side axle tube, no reason for GM to put a tag on it as well.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    yeah, drive for 1 revolution of the tires, see howmany thimes the driveshaft truns.
