GEAR QUESTION
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TB2Blazer, May 14, 2003.
  1. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    Im wanting to put some 3.73's in my front ten bolt axle and currently have 3.08's and was wondering if I need a new carrier for the 3.73's or can I just put the new 3.73 ring and pinion right in?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    no, the carrier break for the 10 bolts is 2.73.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    3.73 /forums/images/graemlins/grin.gif
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Also, if you are going to be paying for new gears you might as well go deeper then 3.73. I would say at least 4.56 or 4.88 with the 39.5 swampers it says you run. You aren't going to gain much with 3.73. Anything is better then nothing, but go as low as possible.
  5. Panther212
    Panther212 Registered Member
    Jan 4, 2003
    56
    Phoenix, AZ
    I agree with hossbaby. If you're runnin almost 40s then you definitely need at the least a 4.56. Might actually be a good time to think about switch out axles as well, if you do a lot of wheeling.
