Gear ratio and mpg
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by achuskies69, Mar 12, 2001.
  1. achuskies69
    achuskies69 1/2 ton status
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green>Well even though i dropped in the new 350 and bolted on a set of Flowtech headers, im still getting crappy gas mileage. ok im running my stock weak ass 10bolts still and there geared 3.08, and im pulling 33" Cooper Discoverer Radials. Are the gears my problem? I planned on going to 3.73's b/c i bought a D44 and GM 12 for cheap and i think they are geared 3.73. But i wanna go to 35's later, so what should i do to keep good gas mileage. Its getting about 9mpg now. I know Blazer Boy gets 16 mpg and he is running 4.56's and 36" tires under a 7" lift.
    thanks for your help....
    <font color=green> I love cowboy hats
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I'd say the gears are hurting your mileage right now. Lugging an engine below its normal operating range kills power (duh!) and mileage.
    I'd go through everything else as well. Usually after headers are installed some carb adjustments need to be made. Cap and rotor good? Wires and plugs? Timed properly? All these things will make a difference. Is the new 350 broke in yet?
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  3. achuskies69
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> Well the motor has about 500 miles on it, has a new set of plug wires, and i guess i need to fine tune the carb a little. There is a new cap and the rotor is good, and we timed it after we got the motor put in.
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Well the axcle swap will help big time now... I have 3.08's and only get about 11 BTW. 3.73's should be prefect for 33's... might want to change to 4.10's or 4.56's when you go to 35's. although the 3.73's wouldn't be that bad.
    1987 Chevy K5 Blazer- 350 TBI
  5. dyeager535
    26,979
    It depends on where you are measuring mileage..I don't think anyone here would claim to get 16-20 city and freeway combined..I doubt its possible for these heavy trucks. As for the gears, my dad, with a 454 and 4.10's, gets 9MPG city OR freeway. Low gears (numerically high)won't hurt you as much in the city as they do freeway. With my K5, 3.08, 305, 700R4,31" tires, I was pulling 17 freeway, and 10-13 city depending if I was easy on takeoffs. I just pulled a 12.5 out of my K5 with 350/SM465/3.42/33's city/freeway without tuning the carb. Lugging can be a problem, but freeway, on relatively level ground, I had no problems with the 3.08's. 33" tires from 31" tires, might make a 500RPM difference, but that still won't be a major issue on flat ground at 60MPH.
    Dorian
  6. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    your engine still has a good 1500 miles till complete break in. if you have a new carb with it, it's going to take some readjusting in the first few thousand miles to get it operating properly.
    i just dropped a 350HO Deluxe in mine and have about 300 miles on it, the holley on it would take attention everyday if i had the time...but its all brand new so you have to expect low milesage. but i agree that your gears are hurting you. i have 3.73s and wish i had 4.56s...currently have 33s getting 35s.
    --adam H
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I agree that the 3.08 gears/33" tire combo is probably hurting the gas mileage some, but don't expect to jump from 9 to 16 mpg with just a gear change. I would think that you would gain maybe a couple of miles per gallon when going to 3.73 gears.
    As for average gas mileage for a Blazer, I would think that something like 16 mpg would be considered exceptional mileage even if it's all freeway driving. I could maybe squeeze maybe 17-18 mpg out of my 6.2 diesel (known for much better mileage than the gas engines) when it had 32" tires and 3.73 gears (O/D trans) and running a lot of freeway. Even the '98 Toyota Tacoma 4x4 with a 4 cylinder and 5-speed I used to have would only get 16-17 mpg, so keep that in mind when looking at the mileage of a carbed 350 in a heavy Blazer with the aerodynamics of a barn door.
  8. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    i just put my open K&N air filter back on b/c it's not as cold here anymore and just with that i get almost 2 extra mpg....
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
  9. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    I've got a stock 87 silverado blazer with slightly larger tires (32" instead of 31") and I'm getting about 12 on the highway ... I do have problems staying in OD going up even relatively slight grades (if they're 1/2 mile or so) would lower gears help this? I do need to replace the cap and rotor and prolly spark plugs, but its got new plug wires (it's amazing how strong the 305 was on 7 cylinders ... 8's even better, really helps the gas mileage, and stops the annoying exhaust too rich codes). any other tips for mileage?
  10. dyeager535
    26,979
    I'd INSPECT the cap and rotor, not necessarily replace it. If its defective, replace it. It's pretty easy to tell visually if they are bad. Plugs most definitely if they haven't been changed in awhile. With the 3.08's, you WILL bog down in OD going up a hill. Solution is to drop it into 3rd.
    O2 sensor a lot of times is cause of bad mileage, but is an expensive item to replace if its not broken. Should be able to check voltage on the 02 sensor to make sure its working while still on the truck.
    Dorian
  11. achuskies69
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> This is a brand new 350, not rebuilt, and it has a new cap and the rotor off of my 305, and it was in good shape, and all new plugs and a new set of plug wires. Im in the Appalachain Mountains, so i drive in 3rd all the time cause of it bogging around in OD, i only use that on the interstate going to Charlotte to see my sisters. I think htat the O2 sensor was replaced when i installed the motor and headers too.
  12. dyeager535
    26,979
    Hmm...I don't know why i assumed you had a newer truck. I don't even think you HAVE an O2 sensor! I wonder if you aren't having some distributor problems, as in advance? Your vacuum advance hooked up? Are the mechanical advance weights free to move? Just went through this on my dads truck, and the weight bushings were gone, and the weights were binding. the vac advance will affect your cruise MPG. Is it hooked up correctly? (timed port, not full manifold vacuum)
    That carb should not need to be retuned if it was running ok on the 305, since the bigger motor will now just be running leaner at cruise. How does it idle? How does the exhaust smell at idle?
    Dorian
  13. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Let the motor break in...they usually get bad milage untill they break in. Sometimes they even smoke a little untill the rings seat. Let the motor break in and then start messing with it.
    [​IMG] Keep your feet dry [​IMG]
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  14. achuskies69
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> yeah i noticed today as i was leaving school it was putting out some black smoke so i guess i have a few hundred more miles before its broke in good...
    <font color=green> 82 K5 - 350, 4" lift, 33's 3.08's
    I love cowboy hats
  15. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    black smoke means the carb is running rich. It'll do that if you really mash on it but if you're driving it normally then it shouldn't. Blue smoke is what i was talking about. A good rule of thumb is to turn the mixture screws on your carb all the way down and then back them out one and a quarter to one and a half turns. That's for an edlebrock or a carter. If you have a quadre-junk, uh..i mean quadra-jet then I don't know how to adjust those or even if you can adjust those. I'm not sure about holleys either. I'm sure someone on this site knows. Hope this helps.
  16. achuskies69
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> yeah im running an Edelbrock Performer 600cfm carb, and i didnt readjust it from when we swapped it over. guess ill have to do it this weekend...
    I love cowboy hats
  17. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Cool! That's what I'm runnin'! That's the way I adjusted it and it's doing great.
  18. achuskies69
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> what kind of mpg are you getting?
    id be happy if i could squeeze out around 11-12.
    I love cowboy hats
  19. kenbrown
    kenbrown Registered Member
    Feb 9, 2001
    20
    Utah USA
    im getting a good 15 mpg out of my k5. i am running a 4" lift and 33 12.5's bfg's at's i have 3:73 gears in my ten bolts. they are going the way as i speak, a 14 bolt sf with 4:56's are taking the place of the 3:73's oh, and its fuel injected which helps a ton in the gas milege area.
    ken with the blue ox (89 k5 silverado)
