??? Gear Ratio conflict ???
Discussion in 'The Garage' started by 77 Mud Buddy, May 6, 2003.
  1. 77 Mud Buddy
    77 Mud Buddy 1/2 ton status
    Oct 31, 2002
    228
    Austin, TX
    I just picked up a set of 4.88 gears for my D44 and 14B FF (10.5" ring gear) After closer inspection I noticed that the D44 gears claim to be 4.89's and the 14B is 4.88. Is this .01:1 difference going to be a big problem.
    This is what I think: (Note: I have a NP203 transfer) on the street is a no brainer, I'll keep my front hubs unlocked and my tranfer in "Lock" on the street and I'll be okay. As for off road, with my hubs locked in, as long as I use the NP203's "LOCK" position, transfer differential not engaged, only when I need it i'll be good to go. What do y'all think!
  2. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    .01 will not be enough to make a difference, 4.10 gears are commonly available in 4.09, 4.10 and 4.11 depending on what axle; yet still usually called four-ten gears /forums/images/graemlins/thumb.gif
  3. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    The difference is 0.2%... your tire's overall circumference varies more than that. Don't worry about it.
    Rene
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    your fine just put them in and go /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Nope, it won't be a problem. The gears in my D44 front are 45/11 = 4.09:1 and the 14BFF are 41/10 = 4.10:1.
    These axles were both under the same truck, so it came from the factory that way. /forums/images/graemlins/thumb.gif
  6. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    count the number of ring gear teeth and divide by the pinion gear teath. That is the true gear ratio.
  7. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    agreed... a .01 diff is no problemo...
    j
  8. 77 Mud Buddy
    Oct 31, 2002
    228
    Austin, TX
    Cool digidy,
    I have not delt with gears much yet so I just wanted to make sure. Thanks for the info y'all.
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    203s have a diff in them therefore it really shouldn't matter
  10. 77 Mud Buddy
    Oct 31, 2002
    228
    Austin, TX
    Yup, that is kind of why I brought it up! My consern was when it is put into the "LOCK" position, it then locks up the internal diff. I didnt know if useing it in the "LOCKED" position would cause any problems with the mentioned gear difference.
    Thanks for input though!
  11. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> 1% difference is fine for the street, 2% is fine for offroad. So you would be fine even with a .04 difference in ratios. /forums/images/graemlins/thumb.gif </font>
