Gear ratio doesnt make sense
Discussion in 'The Garage' started by Blazer guy, Feb 12, 2005.
  1. Blazer guy
    Blazer guy Registered Member
    Jan 13, 2005
    8
    Blythewood,S.C
    I counted 41 ring and 16 pinion. Doesnt this calculate to a 206?Want to change to 411 OR 456 but not sure of carrier series.
  2. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    First, that calculates to a 2.56 which was available from GM. Have someone roll your tires around 1 revolution and count the driveshaft turns. You should get 2.5 turns if your counting is on.
  3. Blazer guy
    Jan 13, 2005
    8
    Blythewood,S.C
    Yep 2.5 turns.12 bolt rear do i need to changr carrier for 411 or 456 gears?Does detroit locker take place of carrier?Thanks for responding.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    THOSE NEED TO GO IF THAT IS CORRECT....
    What deuche-bag thought that would be a good ratio for a truck needs his head examined....
  5. ssls6
    Jan 5, 2005
    86
    Dallas, TX
    You'll need a new carrier for 4 series gears. A full Detroit locker (not the ez-locker) takes the place of the carrier.
  6. Blazer guy
    Jan 13, 2005
    8
    Blythewood,S.C
    Adding the full detroit locker at time of gear change.So i dont have to worry about the 4 series carrier?
  7. ssls6
    Jan 5, 2005
    86
    Dallas, TX
    Yup. Make note that the truck 12bolt is different from the car 12bolt. You'll find something like this:
    Detroit locker for GM truck 12 bolt 3.73 and up.
    The "3.73 and up" lets you know what series carrier the Locker is based on. Keep in mind this is only an example and your locker dealer should have the specific details.
    Some gear sets are bastardized. What I mean is the ring gear is made extra thick so it will work with a lower series carrier. Don't buy bastardized gears if you can help it. The higher the ratio, the smaller the pinion gear because the ring gear is a fixed diameter. The smaller the pinion gear, the weaker the pinion gear.
    I personally would look at using a corporate 14 bolt for anything over 4.10 but that's just me.
  8. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    i secend that . if hard core is in the works get 14ff for all out strenght . 10 and 12 bolts are to small on pinon gear to hold the big power and thay will spit the teeth off the ring gear if used hard or behind high hp motor.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you go with a detroit just order the one for the gears you're using and you'll be fine.
    Either way that 2.56 carrier is garbage and of no use to you.
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    need 4 series carrier, thats not whats in there now,
    this makes about 4th or 5th 2.56 axle ive seen or heard having been found in a gm truck
    3.40 and 3.42 have been the rarest around here, ive only found one of each so far, 77 and 80 respectively, both 12 bolt
    what year make model is the truck
    good luck
    happy birthday tomorrow btw :D
  11. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    Since your running 35" tires i dont think a 14B is needed. You would be doing alot more diff dragging but it has its advantages. If you got a 14b/d44 from a 3/4ton you could have 4.10 gears for a lot cheaper.
    Later
  12. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    yup what he said, for just about 500.00 give or take you can snag some 4.10 geared 3/4 tons. saves you some $$$$$$$$$$$$$
    then sell yoy current stuff:D
  13. Blazer guy
    Jan 13, 2005
    8
    Blythewood,S.C
    Thanx Randy.the truck is an 81 k5 350/350TH/208 10b front 12b rear.256 gear is a mind blower.Would have thought atleast 308s.So thick gears in the front with no locker?Will write up alittle more on this 81 project later and will have alot more ?s.Thanks for the help and a heck of a sight
  14. goldwing2000
    goldwing2000 Guest
    I've got 3.42s in my '80 K-10 and 2.76s in my '89 Blazer. Ain't I the lucky one?
  15. sweetk30
    Nov 1, 2004
    25,548
    543
    for goldwing2000 i found a set of 3.42 gears in 78 heavy half 4x4. just 1 set tho.
  16. goldwing2000
    goldwing2000 Guest
    Thanks but no thanks. The K-10 is headed for the scrap yard, so I'm stealing the 3.42s off of it until I can find some better axles (an M1008, if I'm lucky).
  17. sweetk30
    Nov 1, 2004
    25,548
    543
    no i was just saying that to add to your mental info of whats out there. haha o.k. it was gone a long time ago.
