Gear Ratio for 44's
Discussion in 'The Garage' started by 84gmcjimmy, Feb 2, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Gear Ratio for 44\'s
    Hey, I was wondering what a good gear ratio is for 44" boggers/swampers. For a front dana 60, and a rear gm 14 bolt. my truck has around 400 ponies, thanks.
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Re: Gear Ratio for 44\'s
    What kind of tranny you running?
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    205 im pretty sure.
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    205 is a tcase, what tranny?
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    5.13 since that is as low as you can go in a 14ff
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    yep, but thats still not low enough really
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    its stock tranny i thikn
  8. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    if you are running a 465 205 combo i would run 44's all day long. if you have an auto, i would be concerned about crawling slowly without burning up your trans. ive got 40s and 4.10 and have no complaints running a 465.
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    5.13's
  10. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    To me, it really depends on how you wheel, what type of wheeling you do, and whether or not you are gonna run lockers. I'm running a mild 350, 465/205, 5.13s, front and rear Detroit lockers, and 44" TSLs. I do my mud running in granny gear 4hi if it is deep, if it is really watery or shallow, I can pull 2nd in 4hi. I turn about 3000 RPM at just over 70 mph in high gear. I previously ran the same setup but with 4.10s welded rear, lockright front. 2wd was better and so was street driving, but off road I used 4lo alot more than I do now. With the 5.13s, lockers, 44s, Xover steering and ram assist, crawling is as easy as keeping the rubber side down. I Reccommend 5.13s unless all you run is mud. Also, if you have 3 speed auto with a good cooler AND temp gauge, you could go higher.
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I would be running in mostly mud. what would I use then? /forums/images/graemlins/confused.gif
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I still say 44's with 5.13's is still "high" enough for mud running and still not low enough in general. /forums/images/graemlins/whistling.gif
  13. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    5.13's is what you should get. there is nothing steeper, and anything less will hurt!
