Gear Ratio ID
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HD, Mar 24, 2004.
  1. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    I have a 10 bolt front and rear, and I can not find info on the casting number of this axle. The numbers are:
    "KHB G287 2" also I found two more numbers: "1254333", and GM34 (rear) GM8 (front). Can any one tell me what my gear ratio is on my '83 diesel K5? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Pop the diff cover off and post up the numbers off the edge of the ring gear /forums/images/graemlins/thumb.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    That, or if your gear-sets are the same as how they came from the factory...look in the glovebox and give us all the codes on that sticker that start with "G"
  4. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    I'm going to have to wait on that one. I'm parked on a hill with a starter on order. /forums/images/graemlins/smirk.gif
  5. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    I looked there too, you can not read the writing anymore.
  6. dyeager535
    26,979
    If someone has an '83 parts manual, I *think* that "KHB" is probably the axle code.
    Typically on the passenger side axle tube, about midway between the tire and centersection.
    GM seemed to change the stamped in codes on the axles very often (every year from what I've seen on cars) so most likely the '83 parts manual will be the only deefinitive guide.
    Of course, nothing wrong with popping the diff covers, just not in your case right now. /forums/images/graemlins/smile.gif
  7. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    try turning the pinion and counting how many times it spins to make the tires (both of them) rotate one full revolution. If you get 3.5 turns you have 3.42's, 3.75 turns=3.73's, 4 turns=4.10's. If only one tire spins you'll get double the number of turns at the pinion due to the spider gears. Good luck figuring it out.
