Gear Ratio Identification!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KapeKodK5, Nov 23, 2000.
  1. KapeKodK5
    KapeKodK5 Registered Member
    Mar 3, 2000
    44
    I have a 1990 k5 with stock corporate axles. The sticker inside the glove box is like chinese to me. It is just a bunch of letters and numbers. Not like my old truck that had everything spelled out. I can not find any tags on the axle and I do not have the original tires (to do the rotate and mark and count the revolutions thing) If any one knows how I can decifer these letters to get my ratio it would be much appreciated.......
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You could just pull the cover and count the number of teeth and use the Ring gear teeth/pinion gear teeth=gear ratio formula
    [​IMG]FUN WITH 31's![​IMG]
  3. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    Print the chinese codes in this post. I will break them all for you, or you can pull the cover and count. But you'll spend some dough and get a little greasy......I have hollanders for all 60s through 90s cars and trucks.....js
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Kapkod,
    Here are the codes:
    GU2 = 2.73
    GU4 = 3.08
    GU6 = 3.42
    GT4 = 3.73
    GT5 or GT8 = 4.10
    G80 = Gov-lock
    These are the codes that correspond to your glove box codes.
    Also if you want to know anything about your K5 you can give the last 8 digits of your Vin# to your Chevy dealer and they can tell you all the specs on you K5.
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    While this topic is up top...is there a resource on the Net that we can get those codes?
    SK-15
    J**P...it's whats for dinner!
    http://SK-15.coloradok5.com
  6. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    Dude I think the resource for those codes is CK5![​IMG] I think the only list that gets posted more often is the one for number of post versus title under name.[​IMG]
    Actually I think I have the glove box codes memorized now!![​IMG]
    Rene
  7. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Ah...so they kept the same codes? Thats why I wanted to see if there was a list of em!! Now I can find out...yea!!
    [EDIT]
    Yea..I went out to my Tank and found that its only has G80 in the glove box...now what is the ratio? Or have I missed something here? Mines an 83 and all the codes are in sets of FOUR.....not three?!?!?
    [EDIT END]
    SK-15
  8. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    I just checked out my 88 Blazer and I have 3.73's! I had no idea, thats awsome. Just to be sure, the numbers not in the VIN, its in the glove compartment with all the codes correct?
    Keep the shiny side up, and the greasy side down.
  9. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Walt,
    With reference to what I said about the vin. All Chevrolet vehicles '90 and new can have the the last several digits of vin #'s entered into GM dealers computers and it will tell you about gear ratio's, etc. This is according to my local Chevrolet dealer.
  10. walt88
    May 24, 2000
    430
    Monmouth County, NJ
    but what i am asking is I seen the code GT4 in the glove box, meaning 3.73, did I look in the correct spot.
  11. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Walt,
    You got it right!!!!
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Just as a side note, you can still get a rough idea of the gear ratio by turning the tires and counting the number of revolutions the driveshaft makes...no matter what size tires you have on it. One revolution of a tire is still one revolution, no matter if its a stock 28" tire or a 44" Swamper.
  13. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I hate to sound crazy...but does a G80=Gov-lock have a gear ratio? I don't see it listed here?!?! Thanks
    SK-15
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    It should have G80 and another code with it that would be the ratio. If you have an auto its probably 3.42 or 3.73, and with a nmanual its probably 2.73 or 3.08
    90K5
  15. GUMBY
    GUMBY Registered Member
    May 17, 2000
    35
    Alabama
    What does the G80 designation stand for?
  16. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    where in the glove box? my glove box has2 originall sheets of paper in it, and i dont knw where to look.
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    "DONT BE PROUD IF IT AINT LOUD!"
  17. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I went through my glove box...I don't see anything that says what ratio it is. I took all my codes out and here they are....
    1AJ1
    1A33
    1B32
    1D45
    1G80
    1LH6
    1NK7
    1N33
    1UN3
    1V76
    1YE9
    1ZXN
    1Z58
    168L
    1AD5
    1AM7
    1B3J
    1C60
    1GQ1
    1K34
    1MXO
    1NY1
    1N67
    1U35
    1XXN
    1ZY3
    161W
    And my VIN is
    1G8EK18C1DF100433
    Its a 1983 6.2 Diesel. I can't find the axle RATIO in this goo...I know its a gov-lock...but no ratio listed [​IMG]
    SK-15
  18. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    Hey i got a question. My buddy has an 84 with the gq1 code in it. What is the ratio here? it also has the g80 govlok code as well. Can anybody help me out so i can let him know?
    Later
    Have you driven OVER a Ford lately?
  19. Can Can
    15,555
    146
    Cochrane, Alberta, Canada
    The GM Option code book I have says the following:
    GQ1- AXLE, STD RATIO
    I'm not sure what this means.............looks like you might have to the old tire spin method to find out for sure!!
    Want any other codes deciphered, SK-15?
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  20. 85k5blzr
    85k5blzr 1/2 ton status
    Jan 10, 2001
    103
    Houston, Texas
    Mine must just be different all together. In my glove box, it has the codes and what they are next to them and I am running the gov-loc with an auto and the crappy 3.08. I wish the person that i bought my truck from would have had enough sense to at least go to 3.73 cause 3.08 sucks with my 32"s.
    85 k5 blazer with an old 305....must have more power! [​IMG]
