gear ratio mismatch / tires slipping
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dunc03, Mar 26, 2002.
  1. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    Well for all of those who posted to my last question. I took my k5 back to the guy that installed the new posi, and he said that when he divided the ring by the pinion it came out to 3.10 so he put in a 3.08. I personally have never heard of a 3.10 chevy gear ratio. Is this a possible gear ratio or did he not count correctly. If anybody knows, could you give me the possible gear ratios they put in stock blazer. I think they had the 3.08, 3.43, and 3.73 that went in the stock blazers. I have a 86 with a 305/700r4/np208 with ten bolt diffs. Thanks for the ideas
  2. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    3,10:1? Never heard!
  3. dyeager535
    26,980
    http://www.slosh.com/cars/brochures/blazer4.html
    The specs are all there. Your vintage/vehicle, without looking, I'm going to say 3.08, 3.42, and 3.73 were the only gears available. In the recent past, AFAIK, GM never had 3.10's. Maybe the guy just rounded off to the nearest 10th lol
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I would say pull both covers and check the gear ratio. It should be stamped on the ring gear, but if not count the teeth.
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Yeah, never heard of 3.10's either......but there is really no difference between 3.08 and 3.10 since you are only talking about 2 hundreths. You could probably find more variation in tires due different amounts of wear, differences in air pressure, or simple manufacturing process. You would need at least a difference such as 3.08's to 3.42's to really be able to notice the condition you have.
