Gear ratio
Discussion in 'The Garage' started by CR, Sep 1, 2004.
  1. CR
    CR Registered Member
    Mar 20, 2004
    51
    87 K5 w/ 6 inch lift , 36's , 700R4, 350. Sees medium off- road use. Which gear ratio do you think would be best 4.10 or 4.56 ? Street driving is a factor.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm going 4.56's.
  3. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    4.88 for 36s/overdrive
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]I was kinda thinking that too. But I'm no expert by any means.
  6. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    ya with OD i'd say go as low as u can...5.13's maybe but I would prolly go 4.88's if it where me /forums/images/graemlins/thumb.gif
  7. CR
    Mar 20, 2004
    51
    That low? The guys at the local shop say even 4.56's were to low for the correct rpm's. /forums/images/graemlins/confused.gif
  8. ugly_blazer
    Apr 12, 2004
    1,214
    Go HERE and figure it out, then go tell the guys at the local shop they don't know squat.
    BTW - Your transmission ratio in OD is .7, and your transfer case ratio in Hi range is 1.
  9. ugly_blazer
    Apr 12, 2004
    1,214
    This is what I would pick also, but only 4.10 and 4.56 was offered as choices. If you are re-gearing I would go 4.88, if you have a 4.56 already set up then run it.
  10. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    ya unless yer running a non OD tranny....U can go way low! they are prolly just shooting ya those gear ratios cuz they either dont know much or didnt realize u have overdrive /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Im currently running 4.10's w/sm465 and 38's and I really wanna go way lower, like 4.88's or even 5.13's!!
    Now with my diesel w/TH350 I'm gonna run 4.10's with 35's cuz I dont have OD and diesels dont like to rev to much!!
  11. ugly_blazer
    Apr 12, 2004
    1,214
    I have a TH350 trans and run 4.56 gears. It works out fairly good for a truck that sees some road use (gotta get to the mall /forums/images/graemlins/rotfl.gif). I have 3 sets of tires that I switch between, 35's, 36's, and 38's.
  12. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    what is the rpm range for an small block to be comfortable in?
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I prefer 2200-2600 for a lifted truck to cruise.
  14. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    /forums/images/graemlins/waytogo.gif
