Gear ratio?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silverado_K5, Mar 13, 2005.
  1. Silverado_K5
    Silverado_K5 1/2 ton status
    Jun 4, 2003
    707
    Weston, Oregon
    I'm trying to figure out the gear ratio in my brother's 79 4x4 without pulling the diff cover. I jacked up the rearend and marked the rear driveline and the rear tire. How many times do I need to rotate the tire to get the ratio figured out?
    Thanks,
    Doug
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    rotate the tire 2 times (with only 1 tire jacked up) and count the turns on the drive shaft.
  3. Silverado_K5
    Jun 4, 2003
    707
    Weston, Oregon
    I marked the inside of the tire (33") and rotated the tire two revolutions an counted the turns off the driveline(marked as well) and it was over 3.25 turns but under 3 1/2 turns. So I'm assuming that it's most likely 3.42 gears, or would it be 3.08's? I drove it down the county gravel road at 60 mph according to the speedo, and it ran 2200 rpm. That's assuming the speedo is accurate. Any ideas?
    Thanks,
    Doug
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    More than 3.25 turns but less then 3.5 turns would make them 3.42's since the only other gear would be either 3.08 or 3.73 of which both are either less than or more than your 3.25-3.5 figure.
  5. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    The math confirms 3.42's as well. Should be running at 2207 rpm at 60 mph...
    Rene
