gear ratio??
Discussion in 'The Garage' started by chevy wrangler, Oct 27, 2006.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    what is the stock gear ratio in a 12 bolt and a d44, both half tons?? there off of a 1979 lwb truck:confused::confused::confused::confused::confused::confused:
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Could be anything between 2.73 to 4.10s.....
  3. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    A fairly easy way to find out. When you have the front off the ground, lock the hubs (if PT kit put in), place a crayon mark on the driveshaft, turn the wheel one revolution, count how many times the drive shaft turns. It will get you close to what you have without having to do any disassembly.
    The options sticker (if its still there) provides that information in code doesn't it?
