Gear ratio
Discussion in 'The Garage' started by 1978Blazerk5, Jan 29, 2007.
  1. 1978Blazerk5
    1978Blazerk5 1/2 ton status
    Aug 25, 2006
    2,158
    wisconsin
    hey I have a 1978 blazer on 33's and it has a 12 bolt with 4.56 gears and a factory locker and a dana 44 with 4.56 open diff. my question is do I have to much gear ratio for the size tire im running.Just to let you guys know this is my DD.
  2. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
  3. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
  4. 1978Blazerk5
    Aug 25, 2006
    2,158
    wisconsin
    thanks for the website um accordin to that i should have 4.11 or 4.27 gears oh well 4.56 are fine
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Depends what your drive is like. 4.10 & 33's was too much for my DD at hghway speeds. :shrug:
  6. 1978Blazerk5
    Aug 25, 2006
    2,158
    wisconsin
    my blazer at 60mph is just under 3000rpm's
  7. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    Just put some 35"s on and it will be perfect.
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    That must howel on the freeway! As said, 35's would be better. It will still be high reving but better.
    And 3000rpm at 60mph? Hope you've got some good ear plugs!!
  9. 1978Blazerk5
    Aug 25, 2006
    2,158
    wisconsin
    i accualy drove the thing from california to wisconsin 2100 miles
  10. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    You could always swap in a built 700R4 and have the best of both worlds (low gearing AND low RPM highway cruising). Otherwise I agree with replacing your 33"s with 35"s when it's time for new rubber.
