gear ratio
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rooster53, Apr 30, 2002.
  1. Rooster53
    Rooster53 Registered Member Premium Member
    May 8, 2000
    41
    CT
    I hate to ask a question
    that has been answer a 1000 times
    But could someone tell me the gear ratio
    for a 1988 stock 10 bolt rear
    thanks
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Check your glovebox or pull the cover and see for yourself for sure. There were many ratio's offered from the factory.
    If you're sure the diff or gears have never been swapped look at the codes in the glovebox:
    GU4.......3.08
    GU6.......3.42
    GT4, 5X1......3.73
    GT8, GT5......4.10
    G80.......Gov-Lock
    Rene
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I would pull the inspection cover off, that way you will know for sure. Count the number of teeth on the ring gear and then on the pinion gear, divide the number of ring gear teeth by the number of pinion gear teeth and that will be your ratio. (Like 41 on the ring gear & 11 on the pinion = 3.73 ratio)
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    No need to count teeth...the ratio is stamped on the edge of the ring gear./forums/images/icons/smile.gif
    Rene
  5. Rooster53
    May 8, 2000
    41
    CT
    thank you so much for your help
    you saved me from having to
    remove the cover and all that
    thanks
  6. bigmack
    Jan 3, 2002
    478
    Tennessee
    I have seen several that did not have it stamped on the side of the ring gear. But you are right, if it is stamped on there it is easier than counting.
  7. dyeager535
    26,980
    I haven't seen a GM axle made after 1967 that hasn't had the count on it. (50-100 of them give or take) Besides, all GM parts (that I can think of, maybe not some sheetmetal) have casting, mold or part numbers on them, ring gears are no exception.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    So what did it say you have for gears in there ????
  9. bigmack
    Jan 3, 2002
    478
    Tennessee
    Yeah I know, but there are a hell of a lot of ring & pinion sets out there running around that are not factory GM parts. I bought a Richmond brand a few months back and it was not stamped on the ring gear. So who's to know if this guy has a factory GM r&p in his rig without looking ?
  10. dyeager535
    26,980
    He is if he pulls the cover and changes the fluid/inspects the internals : )
  11. bigmack
    Jan 3, 2002
    478
    Tennessee
    Exactly what I was getting at.
  12. Rooster53
    May 8, 2000
    41
    CT
    It turns out I have
    the 3.08
    thanks for everyones help
  13. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    eeeeeeeeeeeewwwwwwwww get rid of em...they suck
    Later
