Gear Ratios in dodge 60s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Danswift79, Oct 26, 2001.
  1. Danswift79
    Danswift79 Registered Member
    Dec 7, 2000
    83
    Bryan Texas
    Hey guys' I got a question for ya, What gear ratios come in d60s in the front of One ton dodges. I found one and now my rear diff is giving me probs so I'm thinkin time for a swap. Only prob is I need to know what kind of gear ratios are available. Are they the same as GMs and also, would it be possible to match a ratio from a 14-bolt to the dodge.? Thanx for any info. I know about the spring plate distances being different.
    <a target="_blank" href=http://community.webshots.com/user/danswift79> My Photos </a>
    <font color=green> God Blessed Us With General Motors </font color=green>
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Most probably came with 4.10s. The dodge dana 60s and GM dana 60s used the same gears. I would say put at least 4.56s in it.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Ruthiford
    Ruthiford Registered Member
    Jun 25, 2001
    37
    Denver Co
    you have to be care full on 89-93 you could have gotten 3.07-3.54-or 4.10 the one you have to be care full of is the 3.07 causeit could be a dana61 (which means no gear change ops) just be aware on dana 60's most had a 60 casted into one of the case webs 61's had no marking of 61 at all
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    The 3.07s would have come in trucks with the Cummins and the 3 spd 727 auto trans. All the ones I know of are the early ones, like '89-90s.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I could be wrong, but I think 3.07's would only be in 2wd trucks - making 3.07's in a front D60 a moot point.
  6. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    No, they were available in the early Cummins 4x4 trucks. The motors were governed at 2500 (or less), and with no overdrive in the 3 spd autos they had to put 3.07s in them to get any kind of road speed out of them.
    Pete
  7. Danswift79
    Dec 7, 2000
    83
    Bryan Texas
    Thanx for the warnings guys, I guess I am going to just have to get a container to hold the gear lube and check the gear ratio. Any way to tell between a 60 and a 61?
