gear ratios question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by one, Feb 22, 2003.
  1. one
    one Registered Member
    Aug 31, 2002
    28
    redwood city california usa
    Is there a gear ratio guide out there somewhere? I am going to run 35's on my 88k5(10bolt rear) and need to find out what gears I should run with them(daily driver, highway use). Do the 12 and 14 bolts run lower gears from the factory?
    Ben
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Play around with this
    What you're shooting for is to keep the same rpm's at the same speed after you get the bigger tires. For example - in my case, with 29 inch stock tires and 3.42's, a 4.10 ratio would be best for my 33's. So, play around with that to see what you'll want.
    All of the axles (10, 12, and 14 bolt) can have various ratio's depending on the vehicle they came in and the options the vehicle had (ie, towing package, manual tranny, etc). Generally, you'll find 4.10's in the majority of 14 bolts.
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    If you need more torque, gear down (the number gets bigger when gearing down).
  4. Tice
    Tice Registered Member
    Aug 24, 2002
    36
    southeastern arizona
    the new ( april 03) issue of Fourwheeler has a chart in it that may help. /forums/images/graemlins/k5.gif
  5. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    I've used www.4lo.com many times. It comes in handy.
  6. one
    Aug 31, 2002
    28
    Thanks. . . I think I'm going to go with 4:11's.
    As always CK5 comes through again!
    over'n'out
    Grateful Ben
