gear ratios?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillR, Apr 25, 2000.
  1. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    How do you figure gear ratios? I just checked my rear diff. With the rear up in the air, I spun the rear tire once around. The driveshaft turned almost twice around. What gears do I have?
    Thanks!
    Blazin' in Flagstaff
  2. Kodiak
    Kodiak 1/2 ton status
    Mar 17, 2000
    178
    Kodiak Island, Alaska (the emerald isle)
    Are you sure it only turned around twice?
  3. BillR
    Mar 15, 2000
    164
    Flagstaff, AZ
    Sorry, guys. My bad! I had the Mrs. pull it ahead slowly after I marked the shaft. It's almost 4 to 1. Is there a ratio between 3.73 and 4.11?
    Thanks again
  4. walrus101
    walrus101 Registered Member
    Apr 9, 2000
    91
    texas
    not that i know of. if you rolled it forward and you have bigger than stock tires that is probably the difference. same principle as driving down the road and the odometer is slightly off with larger tires.
    walrus101
    goo goo gaju
