Gear ratios
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudbogAD, Jun 29, 2001.
  1. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I have a 79 Jimmy with 3.08 and 35's. Would I notice a significant performace increase if I upgraded to 4.56's.
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Ummm yeah! Although you might wanna consider 4.10's which would be easier on the gas mileage if you are using this truck as a daily driver....but if you are a rock crawler and don't pavement pound 4.56's would rock!
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
  3. MudbogAD
    Jun 29, 2001
    672
    thank you
  4. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Hold up. Few months back I asked about the same question. I do not rockcrawl, but I do offroad trails that are not for the faint at heart. Everybody told me to go 4.56. And now it is 4.10?
    "1988 K5 Grand GT Blazer Silverado in the Netherlands."
  5. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    She was just giving him something to look at and to think about. Like she said he WILL notice a performance increase with either one of those choices. No one is saying that you shouldn't go with the 4.56. It all depends on what you use the truck for and what rpms you are comfortable running at, wether or not you have overdrive and wether you care more about mileage or performance of the lower gears. Lots of things to take into consideration. She was simply pointing out his options.
    <P ID="edit"><FONT SIZE=-1>Edited by 90blzr on 06/29/01 01:42 AM (server time).</FONT></P>
  6. Sammy
    Dec 8, 2000
    250
    So with 700R4 208 35"X14.5" tires. And a need to pull CJ's and TJ's and XJ's out of trouble. Is it still 4.56?
  7. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Just to give you an idea. I have a 700R4 w/241 and 33x14.50 tires and I have 4.10's. It does fine in OD. I am at about 2100 or so doing 70. The 1st,2nd and 3rd gears are good for around town also. I think that with 33's and OD 4.10's are perfect. With your 35's and wanting to pull out the stuck heeps, and the hard wheelin you do, I would say that the 4.56 would be much better for YOUR needs than the 4.10's. This is just my opinion. If you want to check what your rpm's would be at different speeds you can go to www.4lo.com and use the calculators to give you a better idea of what you will be looking at.
    <P ID="edit"><FONT SIZE=-1>Edited by 90blzr on 06/29/01 01:56 AM (server time).</FONT></P>
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I agree with ya 100% 90blzr,,, I have 4.10's now and for a hardcore rig w/ OD I'd recomend it. I like the 4.10's I have... excellent off the line and still gets as good of gas milage on the freeway going 70 as my 3.08's did. They fit well for my daily driver... for someone with a rig that only sees trails and occasional on the street driving go 4.56's no matter what tranny. As soon as I step up to 3/4 ton's and my rig moves to a secondary driver status I'll go 4.56's or maybe even 4.88's since I plan to step up to 38's
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Yes, going from 3.08 to 4.56 gears will give a noticable improvement in acceleration.
    Concerning the debate between 4.10 and 4.56 gears, a lot depends on what transmission you are running. I'm assuminy your '79 has a stock transmission which means no overdrive. 4.56 gears with 35" tires might not be optimum when it comes to freeway cruising and gas mileage, though it shouldn't be that bad (again in my opinion). The newer Blazers with overdrive can get by with much lower gears and still have good engine speed on the highway. A 700r4, for example, has an overdrive gear of around 0.70:1. This means in overdrive on the freeway 4.56 gears would be equivalent to about 3.20 gears (4.56 x .7 = 3.19) in a vehicle without an overdrive trans.
  10. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Mine is a daily driver but I'm going with 4.56s. I love to feel the power on command!!!
    <A target="_blank" HREF=http://www.thehungeronline.com>http://www.thehungeronline.com</A>
  11. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    If I had a 700 I would have gone with 4.56s but Ive got a th350 so I did 4.10s.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got a 700R4, 35s, and 4.10s. If given the choice I think I'd have 4.56s, but my truck has no problem pulling itself down the highway and I can accellerate in overdrive no problem. 4.56s would just be a little more fun. I can get my truck sideways no problem and if I want to I can smoke off my BFGs. I don't though, too expensive!
    Don't laugh, I've got a built 305. I know I'm dumb for building up a 305, but it's all I had. It was supposed to be a 350. I got screwed over on that deal, so did the PO who was sold the motor for $1000. I paid $100 for it and it's got a LOT of power. You'd be amazed. But it's still a 305, which bothers me.
    Tim
  13. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I have the 700R4 and run 33's with 4.56's My gas mileage around town is a little better then with the 3.08's. I'm not hitting the skinny pedal as hard to get up to speed. I am tacking around 2200 at 65. It is not my daily driver. But most of the driving is around town. If I had to do my gears again I would go with the 4.88's. 4.56's are not as bad as everybody thinks........Just my .02 worth
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think 4.56s would be nice to have, but 4.10s are good too. Even 5.13s wouldn't be that bad with 35s, 2500 rpm at 65 mph. All depends on how snappy you want it, and if you plan on bigger tires, go lower.
    Tim
  15. MudbogAD
    Jun 29, 2001
    672
    I think i will go with the 4.56's because i am not too concerned with mileage and rpm. I want performance! Thanks all !!!!!
  16. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    youll be using the truck as a daily driver, i know you will, 4.56s would be nice if you go up to 36" and inflate them all the way so they're actually 36" tall unlike your 35s witch measure out at about 33" due to the pressure you run. that truck sucks on mileage already what are you gonna drive if your mileage gets worse? the van? i dont think so. that truck has got PLENTY of power so 4.11s would be ok for you. certain companies make 4.33s too, think about those. i think if i were you i'd go with 4.33s.
  17. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Hell just drop some 5.13's in it! Actually, with OD, I'd go with 4.56. If you had a TH350 or 400, then 4.10 would work. I have 38's on my Blazer with a TH350 and I'm prolly going with 4.88 or 5.13. I'm also going to drop my 3/4 ton drive train in too. Mine's a daily driver with expired tags too!
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  18. MudbogAD
    Jun 29, 2001
    672
    scott/muddsub. You have 29 inch tires and 3.73's. You probaby get worse mileage than the jimmy would with 4.88's. My Jimmy never drives on the highway or freeway so I think 4.56's will do fine. Especially if I am going with the 36x12.50 very soon.
  19. muddysub
    Jun 23, 2001
    10,451
    489
    hey adam they're 30s ok and i wont have them for long
    scott,
    1989 suburban 3/4t 4" lift soon to be rollin on 35s, tbi350
  20. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Go with the 4.56. It is not a car, it is a truck. Trucks have low gears. Now, so you don't think I'm a nut, the reasons. My '80 has no power from the motor: stock 350, 21years & 200,000 mi. When I replaced the flexplate I could turn the motor by hand, plugs in, w/o gloves. Before the gear swap it would not start good, slow down good, and would not crawl at all. With the 4.56s it is like a new truck. The gas mi sucked before and it still does now. Once again, it's a truck. This was my daily driver untill I started my new job with a 90 mi/day commute. The first month I drove it to work in Atl traffic. It still keeps up fine untill about 70MPH. If you have a good motor you'll be even better. The guys with the 4.10s wonder about 4.56s. The guys w/4.56s wonder about 4.88s. With 35s & no O/D 4.56s are perfect. 35s & O/D, go with 4.88s. One thing to remember, only BFGs and Swampers are true hight.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
