gear ratios
Discussion in 'The Garage' started by gmc4cw, Dec 21, 2006.
  1. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    what gears are you running with what trans/T-case(s) and tire height.
    I have a 700/241 with 4.56 gears and 44's. looking into some different gears and would like to know what works for you.
    mine is trail only.
    thanks for your input.
  2. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    wow, you are viewing this but not responding. you have a trans and t-case right. you probably have gears in the diffs too. all responses are encouraged.
  3. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    700r4 slush box w/ super slipping...
    np208
    10b's w/ 3.08's
    38.5" MT Baja Claws
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    SM465/205, 4.56 gears, 37" tires.
    If you are looking for deeper gears you are probably looking at a doubler/atlas or a dana 70 rear end.
  5. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    I have a th400/np208 4.56:1 gears and 38" ground hawgs
  6. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    np203 w/ partime 4.56 with 33"s soon to be 35"s
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    700/241/4.56's/35's
  8. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    700/241/4.56
    35's for the street, 38.5's for the trail
  9. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    465/208/456's/38.5" Could stand to go with 488's but it does really well as is.
  10. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    305/700R4/NP208 14 bolt FF, 10 bolt 3.73 gears and 35x12.50x15
    It sucks
  11. Uncle Fester
    Uncle Fester 1/2 ton status
    Mar 23, 2006
    229
    Cheyenne
    1978 Chevy Suburban
    350 ci 4 barrel, SM-465, NP205, 10 bolt front w/3.73s,
    12 bolt rear w/3.73s, 33x12.50x15 ATs
    UPDATE, now has 35x12.50x15 Dunlop Radial Mud Rovers
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I gots me a 700R4 and 208 with 4.10s and 37s. The gear is too high 3rd revs too high and OD is too low of an RPM. I will be going with 5.13s and a doubler or 3 speed stak behind a NV4500.
    Ira
  13. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    465 tranny with a 203 range box +WMS 3.198 gear set in front of a 205 case going to 5.86's in the chunks turning 36" tall SX's .
    Tom
  14. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    700r4/np241/4.10 gears with 33s. It's ok for the way it is now.
    I'm going for 700r4/203,205 doubler/5.13s with 37s
  15. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    If the truck is truly "trail only" there is no reason not to go as deep as possible..... which is 5.13s if you're running a 14BFF.....7.17 (or something like that) if you're willing to swap in a Dana rear end.
    I'm assuming you already have a D60 front since you are running 44's.
  16. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    700r4/208 5.13s and 39.5's
  17. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    350/700/203/205/4.10 36-12.5-15 i want 5.13/5.38's and 39.5's
  18. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    doublers are expensive. What would I gain from a 70 rear end?
    This truck has been in overdrive only a handful of times in the last 7 years. not once this year, and only once last year when I was messing around on the road in front of Paragon. Pretty much keep the lever set to 4lo all the time.
    would 5.38's be too much? right now I have a 38:1 crawl ratio not counting converter slip. 5.38's would put it at 45:1. not much but a step in the right direction.
    If I did a doubler I would like a klune-V since you can mount anything behind it. and its lighter then a 203. my truck weighs enough already. so if I did a 205 behind that it would still be short. with 4.56 gears I would be at 75:1. same setup with 5.38's would be 89:1. not too shabby.
    I'm thinking out loud here.
  19. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    yes its a 60/14 bolt combo. geuss 5.13 is the way to go since I don't feel like swapping axles again.
  20. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    487
    New Hampshire
    465/208/10b/4.10/35"s
    crawl ratio - 70.1:1 :bow:
