gear ratios
Discussion in 'The Garage' started by 1983Blazerkid, Feb 6, 2007.
  1. 1983Blazerkid
    1983Blazerkid Registered Member
    Nov 12, 2005
    98
    brownsburg, in
    i know i know ive looked it up but the charts say for a manual trans or whatever. well i have a 700r4 so i know its going to change things. but which way i want to run 38s for now but ill prolly back it down to 35s or somewhere in that range. just want to know what gears i should be looking for. ive got a 350/ 700r4/208 thanks for the help cody
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I think you could get away with 4.88s in the 35-38" range....
  3. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    4.88 or better for 35's to keep from killing tranny.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    4.56 for the 35"
    5.13 for the 38"
    4.88 in the middle
    What do you do with the truck?
  5. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Take the RPM # off the manual charts you were looking at (I assume a 1:1 transmission ratio) and multiply by 0.7, which is the OD ratio of the 700. In OD the torque converter is locked, so you don't have to consider any slippage in the calculation. You can also calculate your RPMs"
    Engine RPM = [((miles/hr) x 336) / (tire diamer) ] x axle ratio x transmission ratio
    Example: [(65 x 336)/35] x 4.56 x 0.7 = 1992 RPM
    There are calculators on the web to do this, but it's handy to know how and do it yourself.
  6. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I will sonn have 38x14.50R16.5 super swampers TSLs And I will only have 4.10s I will let you know how it feels.
  7. 1983Blazerkid
    Nov 12, 2005
    98
    brownsburg, in
    thanks for all the info guys cody
  8. 1983Blazerkid
    Nov 12, 2005
    98
    brownsburg, in
    i mostly just play with it. dont know if im going to ever drive it on the street again. but i have 35s now and the gears suck. so im going to fix that. then maybe if it helps alot i might start driving it again
  9. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I've got 4.10's with 38.5's that measure out to 37....it feels fine and thats even with a slipping tranny. We have the same exact setup too...sb350/700r4/np208...
    Something else to keep in mind is the 700r4 has a pretty low 1st...but again it depends on what you do with it...If you aren't going to keep it on the street just go 5.13's and be done with it...if you might keep it on the street go 4.56/4.88 (probably won't see a huge difference between the two).
